VS2020 Crashing when playing MOV files
JohanGr
- processor: Intel core i3
- ram: 4gb
- Video Card: nvidea
- Corel programs: VideoStudio 2019/2020
Hi, I hope this is the right forum to post this to.
I have been using VS2019 Ultimate and upgraded a couple of days ago to VS2020 ULT. Most probably this was not such a good idea as it costed money and does not work for me?
For our church I edit and render our services into Youtube video's. The source files are always "MOV" files recorded by "BlackMagic studio" hardware.
Using VS2019, I had no problem except that VS and Google/Youtube did not agree on the Internet explorer's security features when uploading. I could live with that, but purchased the new VS2020 to overcome this and some other nigly items.
Now, here's the problem: In VS2020, I can add the MOV file fine to the project. I can add it to the timeline. I can move the playhead anywhere and the preview screen updates accordingly. As soon as I click on the "Play" button, VS2020 just simply shuts down without warning. It seems that VS2019 still works after the upgrade to VS2020 and if I try the same function described in VS2019 it seems to still be working fine. I can replicate this over and over and have not been able to fins any work-around.
It is not a corrupted MOV file and it's a shame that paying and upgrading to a "better" version has actually put me in a position where I cannot use the software?
I'm open for suggestions if anyone has any advice for me.
Kind Regards,
Johan.
Kind Regards,
Johan.
Re: VS2020 Crashing when playing MOV files
Hi Johan
And welcome to the forums
Sorry you are experiencing problems with your video files (Mov)
As you describe 2019 not having this problem we can only assume that 2020 does indeed have a problem.
First can I ask if you have QuickTime codec installed on your pc, if not then I would try installing that.
Some details on this post with a link to YT
You may wish to jump to 3min 38 sec ish
If installing QT codec are you able to provide a sample s o we can test, we do not work for Corel so you should also contact Corel Support
And if I can replicate I would also pass this on.
Otherwise I would revert to using 2019
Of course you always have the 30 day money back guarantee to fall back on, bit of a pain though.
As for uploading to YT through the program i dont think anything has changed with 2020 unless you know different
But we can render to a video file and upload from our YT accounts.
JohanGr
- ram: 4gb
Hi Trevor and thanks for the quick reply.
Yes, the Quicktime codec is installed, otherwise 2019 would have worked. I also remember installing it when I started with VS2019(Actually X10 before that).
Not too sure if you were meaning to post a YT link...(Once the codec is installed it's usable by all apps right...even if the app is installed afterwards)
I'll see what I can do about a sample as the MOV files which I have are very big....too big to send electronically. I might have a smaller one somewhere.
I have posted this to the Corel Support email as well.
I doubt I'll get a speedy answer like yours
Johan.
Johan.
Hi Johan
I had assumed you were using VideoStudio to access and upload your video files to You Tube
Some do have problems with that approach and the only advice we can give is to use your own account to upload your files.
Sorry for any confusion
The QT codec
Not all Mov files need to use that codec we do know that some mov’s can work without.
You could try renaming the Mov to use MP4 as its extension, I would first create a copy of your file just in case renaming the file messes things up.
The original MP4 were derived / created from Mov flies as such some can swap the extension.
Its worth a try ---- although clutching at straws
How large are your video files, uploading is the slow part with servers limiting upload sizes, but thats in Gb?
The QT codec
mikelehman
I'm having the same problem. I was able to use VS2020 for a while, but last week it started crashing whenever I would try to preview/play a .MOV file or try to render a video with a .MOV file. The program would simply shut down. I tried using a .MOV file that worked in a successfully rendered video before, and VS2020 crashed with that file too. Perhaps this started after the last update?
Some users had problems when Hardware Acceleration is selected
Can you try deselecting that option
I have just tried editing and rendering Mov files with no problems so far.
Of course there are may types of Mov.
I have not added any transitions or any other edits, just added clips to timeline and rendered, Same as Project / Clip and to MPEG4
PWComp
- motherboard: Dell 0FHJFF Ver A00
- processor: Core i5 10th Gen
- ram: 8Gb
- Hard_Drive_Capacity: 500Gb
I've just bought and installed VideoStudio 2020 Ult and it just keeps shutting down whenever I select the play button. I have tried running repair, I have also unistalled and reinstalled but still keeps shutting down. The last thing I tried to do was to link two png images, with the Face transition link. Help.
mikelehman
I did try deselecting the hardware acceleration as well and the software still crashed. VS2020 will crash (not freeze, but just shut down) even when in the "Edit" tab when I try to play the file. I could compile several .mp4 files and render them with no problem, but the .MOV files crash VS2020.
Hi Mike
Are you able to share some of your Mov files assuming they are not too large
We can try to replicate your crashes.
You would have to upload to a sharing site then provide a link to download the files.
I have tried using a couple of types, one from a Panasonic TZ camera using 30fps Photo-Jpeg and some from a Canon 7D at 25 fps H.264 High Profile with no issues so far, I’ll keep pushing it.
Right click your clips on the timeline - Properties -- what are they?
mikelehman
I included a small file I recorded today. Let me know if you'd like a couple of others, but all the .MOV files I have are doing the same thing, including ones that rendered fine before. I tried this file in my VS2020 and the software crashed/shut down immediately when I tried to preview/play it in the Edit tab. I am using a Zoom Q8 camera for the videos. Thank you so much for the help!
Mike
https://1drv.ms/u/s!AgFo13QYEakxgqkLeiU ... g?e=hIlZsL
Mike
- RobertOZ
- Hard_Drive_Capacity: 7 TB
Agreed your video does crash VS 2020 as soon as play is selected, however, convert to mp4 and it plays fine
canuck
Jusr change the mov extension to mp4 and it plays fine in VS2020. No need to convertmikelehman wrote:I included a small file I recorded today. Let me know if you'd like a couple of others, but all the .MOV files I have are doing the same thing, including ones that rendered fine before. I tried this file in my VS2020 and the software crashed/shut down immediately when I tried to preview/play it in the Edit tab. I am using a Zoom Q8 camera for the videos. Thank you so much for the help!
Mike
Candive
- Corel programs: VS2021, VS2023, PSP2021, ASP3
For what it is worth, the file plays in VS X10 just fine.
- RobertOZ
Would have suggested that canuck, but when I download the file. it did not have a .mov extension, in fact it had no extension just ZOOM002canuck wrote:Jusr change the mov extension to mp4 and it plays fine in VS2020. No need to convertmikelehman wrote:I included a small file I recorded today. Let me know if you'd like a couple of others, but all the .MOV files I have are doing the same thing, including ones that rendered fine before. I tried this file in my VS2020 and the software crashed/shut down immediately when I tried to preview/play it in the Edit tab. I am using a Zoom Q8 camera for the videos. Thank you so much for the help!
Mike
All versions of Video Studio from X9 manage the file ok which plays with volume, although not a lot there, properties show an audio stream using Compression 24-bit Integer – whatever that is.
Video compression is shown as Ambarella AVC encoder
Using 2020 I can add to the timeline but trying to play in either Clip or Project crashes VS - Silent Closure
Rename the file to use MP4 and the video does play but does not have any audio stream, the video shows as H264
This does appear to be a problem with 2020
I converted the file using CVS 2019 but the quality was dreadful, using other conversion software may produce better quality
