To use a Mask Frame within Videostudio 2019, I did the following:
1. Clicked on a clip that is on a overlay timeline.
2. On the Option panel, Effect tab, clicked on Mask & Chroma Key.
3. Clicked Apply Overlay Options, then selected Mask Frame,
But no Masks appeared in the window - nothing is showing.
Am I doing something wrong, is the Masks file missing? If yes, how can I download the Mask file?
Thanks,
Steve
Mask Frames Are Missing
Re: Mask Frames Are Missing
Hi Steve
and welcome to the forums
I have moved this topic from Forum Chat to the Video Studio forums
As image there should be 14 masks in the Frames
I think they may be here, having said that they could be anywhere?
C:\Program Files\Corel\Corel VideoStudio 2019\Samples\Image
M01.bmp is the first
You can then try the + Mask Item and navigate to pick a BMP, should not have to do that.
You may be best to reset the Library, that will remove your personal folders so do a Library Export to save your folders
Then do a program reset by renaming the 22.0 folder to 22.0_old
A new folder will be created when launching VS
C:\Users\Trevor\AppData\Roaming\Ulead Systems\Corel VideoStudio Pro (x64)\22.0
Post updated
I ran a test, removed the M01.bmp from the folder
Lost that in Mask Frames
Replaced the M01.bmp but did not show till I had reset the program by renaming the 22.0 folder
Post updated
