CVS2020 Update SP4 available
Topic updated 26 august 2020
Service pack SP4 is available to download and install through the program
SP4 updates CVS 2020 to version 23.3.0.646, from Help About if this shows then there is no need to install SP4
Some info from Corel here https://www.videostudiopro.com/en/support/updates/#
Using Video Studio, we should receive an automatic notification that updates are available.
Otherwise use Help Check for updates
SP4 is approximately 1.5 Gb and may take some time to download and install, be patient.
This is a list of problems that SP4 addressed
Acceleration setting in Share does not match setting in Preferences
VSX10 / 2019 / 2020 - DVD menu template not saving and reloading
Crop doesn't work correctly
Media Library Animation not working (Beta-0404)
Upgrade to the latest Canon SDK for Stop motion
Can't add specific image to timeline, if in thumbnail mode
360 Video from YI 360 VR camera cannot be used
Youtube login fails
Rename label "Surround Sound Mixer" to "Sound Mixer"
[Painting Creator] Color shift when converting animation to Still image
Unable to set background video to menu
Crash when edit and preview in Subtitle editor
Drag a transition, VSP crashes
Subtitle Editor - VSP crash when scaning
VSP crash when double click a title
Crash, or unresponsive cursor after opening a project created in VS 2019
Cannot set a (€) character with the keyboard
Prefs, PnZ, Mask, Library, FX sizing problem in 1680x1050, 1440x900 and 1280x800 (Beta-0464)
MCC Lite created green clip and cause VS crash
Older service packs
We are now aware that Corel have provided a program update
I have no details of any fixes as yet
Please go to Help - About to verify your version - New version should be 23.1.0.481
If you do not see this version Please go to Help Check for updates to download
Follow details to install - this is the only option to install the service pack
Please close Video Studio whilst installing the patch
Post Updated 08th May 2020
Below are details of fixes addressed by Service Patch 2.
Can't move a clip from one bin to another
Painting Creator - custom brushes, add delete option
Can't drag an imported path to another folder
Painting Creator: some textures show grid lines when they shouldn't
Video Duration clock discrepancy
Youtube login fails
Apply FX to SRT, app hangs for several seconds, then crashed in operations afterward
FX Background Blur has no effect, can't customize
Garbled texts in Share - observed in French and German
LUT "Invert" effect isn't shown, just solid gray
Share: text overlap and translated incorrectly
When VS2019 and VS2020 co-exist, open project, 2019 will crash.
Timeline settings aren't adjusting to a new clip format, and clips in Library will be displayed in wrong sized icon
Project Properties: "Show All" option, scrollbars, and make the window bigger
Request: remember last used project bin, display it at program launch
Can't customize 9:16 profile
Crash when playing merged title and media clip
Solid color, context menu, missing Video track and Overlay track #1 options.
Highlight Reel: dates not localized
Highlight Reel: imported reel, aspect ratio is incorrect
Move CC titles to All
Highlight Reel, German translations
Tooltip localizations
Highlight Reel crashes when delete a photo
Imported LUTs are displayed incorrectly
Roll editing isn't adjusting cut as expected
Add effects into Popular folder
Hang when click a CC title
Clip preview problem during trimming, if on overlay track
Upgrade, serial number pass-through issue
Crash when adding mts in Share->Disc "Add Media"
Mask Creator: title position inconsistency in timeline
Customize Filter won't open
LUT profile library UI problem
Localization error in Welcome Start page
Mask Creator: one pixel can't be masked, at right edge
Mask Creator: can't edit a still mask a second time
Mask Creator: feather on / off, doesn't correctly restore to previous state
Adjust audio volume has no effect
Bring Title safe area back
Support drag the clip end, to extend as frozen frame
MOV thumbnail and playback problems
Crash applying ProDAD Mercalli
VS crash when change photo duration
9x16 video is rotated, when switching aspect ratio in Properties
Regression: MCE: preview incorrect, and smart proxy behavior issues
Some 4K clips preview black
Some clips are still appearing in Library with wrong aspect ratio
New library folder rename, position cursor, Improper Argument error
Mask Creator, errors in Zoom
Mask Creator, restore Smart Brush and Smart Eraser
Crash when export to Mpeg-4 AVC 1920x1080 30p 15mbps
Uninstall Highlight Reel, receive error message that it's still running
Project Properties, can't delete a preset
Add clips with gap, thumbnails won't display in Storyboard mode
Crash when export Blu Ray to ISO image
Color Grading - "Save as present" files are not exist different type clips
Warning dialog is missing when changing project format
Crash when drag transition on overlay track
Crash when opening a 3D Title
Failures to Save or Open project
AIFF audio is mute
Crash, or the transition changes when move a group
Sample_lake preview includes green at edges
Profile description has wrong bitrate
Keep Aspect Ratio loses the original ratio
Errors when a Highlight Reel project is saved
Crash when add same length clip to Mask
Specific .mov cannot be imported
Highlight Reel should not create a new folder
.mkv audio glitch
Invert mask, re-edit and mask is lost
Library folders re-order, include Popular
9x16 formats are displayed as square
CC Titles moved to All folder
VS UI is stretched after closing Highlight Reel
Don't display H.265 option when unsupported
Crash when apply NewBlue Titler Pro 5
Basic shape, border is incorrect
Painting Creator - brush shape changes after selecting a color
Playback is not paused when opening Highlight Reel
Youtube login fails
Older service packs
Youtube login fails
AIFF audio is mute
.mkv audio glitch
- Davidk
- ram: 16Gb
- Hard_Drive_Capacity: 6Tb
Re: CVS2020 Update available
This update does not fix panel size issues advised and commented on elsewhere.
Waddie
- motherboard: Gigabyte B360M DS3H
- processor: Intel Core i7-8700 CPU 3.20GHz 3.19 GHz
- ram: 32.0 GB
- Video Card: NVDIA GeForce GTX 1060 3GB
- sound_card: NViDIA High Definition Audio
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: Dell P2419H
- Corel programs: Video Studio Ultimate 2020, PSP 2019
Pretty happy with the update. So far it has fixed the problem I had with VS 2020 randomly closing when I tried to use video stabilization, color correction and actually when I tried to perform almost any function in VS 2020.
Prior to the update VS 2020 was totally unusable! I was actually shopping for another video editing program. Have my fingers crossed!
Thanks for that, nice to get some positive feedback...Waddie wrote:Pretty happy with the update. So far it has fixed the problem I had with VS 2020 randomly closing when I tried to use video stabilization, color correction and actually when I tried to perform almost any function in VS 2020.
regards
leszektrojanowski
- motherboard: Intel H670
- processor: Intel Core i7-12700 Processor
- Video Card: NVIDIA GeForce RTX 3070 8 GB GDDR6X
- sound_card: Realtek High Definition Audio Device
- Hard_Drive_Capacity: 3TB
- Corel programs: VS 2021 Ultimate
I was having the same issue. Every so often the programme would just shut on me with no reason.Waddie wrote:Pretty happy with the update. So far it has fixed the problem I had with VS 2020 randomly closing when I tried to use video stabilization, color correction and actually when I tried to perform almost any function in VS 2020.
I also hope the audio issue has been resolved (I haven't been able to test it yet). Previously you couldn't lower the volume as it would stay the same no matter what you would put.
Suppah2
- ram: 8gb
- Hard_Drive_Capacity: 17tb
Hello,
I can't install update....
it gives me the error attached.
I attach also my system
I also tried to find the update on my pc to remove it and re-download but i don't know where is stored
Let me know.
Tnx in advance
Regards.
Let me know.
Tnx in advance
Regards.
Please go to Help – About – what do you see
My version shows as 23.1.0.481
If you see that then your program is upto date and does not require this service pack
Any new installations will install the latest version and the service pack will not be required
If your version is different go Help – Check for Updates
That is the only way to install service packs, we can no longer download service packs from Corel.com
If check for updates does show that one is available it should auto install
The actual file will be saved here
C:\Users\UserName\AppData\Local\Corel\VideoStudio2020
Suppah2
- ram: 8gb
I solved the problem doing this things:
First mi version VS2020 was outdated.
I tried by autoupdate but was not working, so i opened the folder you told me and i executed vs2020_sp2.exe with right click on mouse and selecting AS ADMINISTRATOR
doing this the update is now installed and updated to .391 to .481
Hope this will help anyone could have my same issue.
Regards.
Regards.
Luna Esterhuizen
- motherboard: DELL XPS 15 9520
- processor: Intel Core i7 12700H
- ram: 32 GB DDR5
- Video Card: GEFORCE RTX 3050 4GB DDR6
- Hard_Drive_Capacity: 8TB
- Monitor/Display Make & Model: Dell 1920 X 1200
- Corel programs: Video Studio Ver 9 to VS 2021 Ultimate
Mine is still crashing all the time latest when I tried to add NB Titler EffectsWaddie wrote:Pretty happy with the update. So far it has fixed the problem I had with VS 2020 randomly closing when I tried to use video stabilization, color correction and actually when I tried to perform almost any function in VS 2020.
L E
HelloLuna Esterhuizen wrote: Mine is still crashing all the time latest when I tried to add NB Titler Effects![]()
can you please confirm what happens on a crash
Does the program simply disappear from your desktop
or does the program become unresponsive where you use Task Manager to close the program
any other info?
ScottieD
- Corel programs: VideoStudio 2020 Ultimate
The update has caused me a world of pain. Firstly the upload just kept uploading, it would finish and then continue to upload again. I could not make it stop. Then I noticed the the Boris Titler FX had disappeared from my effects list. I tried uninstalling and reinstalling, no change.
I've gone to Corel Help and with reductions in staff it has been going on two weeks with no resolution. They sent me a second exe file and instructed me to switch off my fire wall and virus protection. It downloaded and started to install, got to 997 GB downloaded then dropped back to 925 GB and kept going through this loop, never fulling loading.
I've now provided Corel with system analysis so they might be able to figure out what is going on. But until the recent update to CVS2020 everything was working perfectly fine.
Anyone else got problems?
Hi ScottieD
and welcome to the forums
I have not had a problem installing the program, I did choose to uninstall and re-install rather than applying the patch. I created a new download folder so I could download the entire program again.
I see the programs installation files as 6.76 Gb - The Service Pack SP2 was approx 1.5 Gb
So I do not understand your sizes of 997 Gb is out of this world
I assume Corel advised you to uninstall and re-install the program.
Downloading the SP2 file should save here
So if SP2 did complete the download at any time you could try installing from there.
I see the file as VS2020_SP2.exe at 1.501,897Kb
Luna Esterhuizen
- ram: 32 GB DDR5
Hi Trevor,lata wrote:HelloLuna Esterhuizen wrote: Mine is still crashing all the time latest when I tried to add NB Titler Effects![]()
any other info?
I'd spent two days now trying to fix my pc as I was totally unable to go on with my project. First, since version 2019 if I use the in/out zoom slider the cursor just get stuck for a while. You cannot move it. This never happened with any other version. I've learned to press the Windows key and then it released the cursor.
There were different things that did that caused VS just to freeze or it just jumped totally out of the program. Simple things like moving a clip to another position in the timeline was the most annoying thing. Adding the New Blue fx etc I cannot recall them all.
It was so frustrating that I searched the internet, looking for other programs to try out. I even downloaded Blender and Da Vinci Resolve, as many gave excellent reviews for these two. Needless to say I found it difficult to learn a new application while I was desperately trying to finish a project.
So I then changed my hard drive that I replaced few months ago. I installed VS there and immediately could see that the program runs better. Then changed back to the new hard drive, did a clean system installation and installing everything back on my pc. This is time very time consuming but I wanted to make sure that the problem is not with my own hardware. I will only start to edit now and see how it goes. I will let you know how it goes. Thanks for your response I always learned a lot from this forum. I will update my hardware on my profile.
NS: I'm working on a 4k project which is also something that concerned me, if VS can handle it. I did make proxy files. Now that I did a clean install (my proxy files is on another partition) I guess I have to create proxy files all over again, which is also very time consuming.
L E
Thanks for the update and hopefully your efforts to re-install and clean the drives will do the trick
Smart Proxy
I would think after all the work that you may have to create again
I have my programs installed on the C:Drive and a proxy folder created on the D:Drive aptly named “All Proxies”
I have several versions of Video Studio installed and all are using the same proxy folder.
Interestingly creating proxies using say X10 will also be used when running any other version, of course using the same files
As far as I am aware proxies are retained when re-installing my programs.
But then not a big deal to create proxies again, we can do that from the library or timelines, a little time to create, but that’s one think we have at the moment, just means a longer coffee break
Smart Proxy
ScottieD
Unfortunately mine says VS2020-SP2.exe.partlata wrote:Hi ScottieD
