2019 - Program Freezes when import media file
PeterRueth
- processor: Intel i5-8365U
- Hard_Drive_Capacity: 200GB
- Corel programs: VS Ultimate 2019
I am trying to insert an .mp4 file into VS to edit. It's approximately 9 mins long and 57.1mb. The file is located on local desktop. when i select the file to insert...VS freezes. I have to start Task Manager and force shut down. Any insights?
Re: 2019 - Program Freezes when import media file
Welcome to the forum.
Can we assume there was nothing special about the mp4 file? Did it come from a smartphone? If so, did it have a variable frame rate. It would good if you could send us the properties of the video. Using the free MediaInfo app would give us the best set of properties...
PeterRueth
Hello Ken
Thank you for such a quick reply.
Does the attached .png provide enough info. Happy to get more if needed...
This video was captured via the Zoom application. I tried to import another mp4 file that was recorded during a zoom meeting...same results.
Have no problems opening the video in media player.
- Attachments
- Capture.PNG (6.06 KiB) Viewed 854 times
PeterRueth
I have attached MediaInfo extract...pasted in body and attached.
____________________________________________________________________________________
General
Complete name : C:\Users\Fairway User\Desktop\VincentInterview.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 55.8 MiB
Duration : 9mn 11s
Overall bit rate mode : Variable
Overall bit rate : 848 Kbps
Encoded date : UTC 2020-03-27 19:29:48
Tagged date : UTC 2020-03-27 19:29:48
_____________________________________________________________________________________
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L5
Format settings, CABAC : Yes
Format settings, ReFrames : 11 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 9mn 11s
Bit rate : 792 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.034
Stream size : 52.1 MiB (93%)
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 9mn 11s
Bit rate mode : Variable
Bit rate : 53.4 Kbps
Maximum bit rate : 110 Kbps
Channel(s) : 1 channel
Channel positions : Front: C
Sampling rate : 32.0 KHz
Compression mode : Lossy
Stream size : 3.51 MiB (6%)
Title : AAC audio
Thank you!!
Peter
General
Format : MPEG-4
Codec ID : mp42
Duration : 9mn 11s
Video
Format : AVC
Codec ID : avc1
Duration : 9mn 11s
Bit rate : 792 Kbps
Height : 720 pixels
Color space : YUV
Bit depth : 8 bits
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 9mn 11s
Title : AAC audio
Thank you!!
Peter
- Attachments
- MediaInfo_VincentInterview.mp4.txt
- MediaInfo extract
- (1.61 KiB) Downloaded 61 times
