Convert GIF to MP4
jimkirk363
motherboard: ASUS ROG CROSSHAIR VII HERO WIFI
processor: AMD Ryzen R9 3900XT at 4400 Mhz all Cores
ram: 32GB
Video Card: Inno3D NVIDIA GeForce GTX 1080 X2 8GB
sound_card: ROG SupremeFX 8-Channel High Definition Audio
Hard_Drive_Capacity: 41497 GB
Monitor/Display Make & Model: 1x U32J59XUQ (Main) 1x Samsung U28E590 (Secondary)
Corel programs: PSP ULT 2022, 2021, 2020,Aftershot3 Pro.
Convert GIF to MP4
Post by jimkirk363 »
Is there a way to convert a GIF to MP4 using Corel Video Studio 2019?
If so how do i do this please?
Thanks.
Re: Convert GIF to MP4
I would have thought you would just put the GIF in the VS timeline then simply go to Share and choose a specific video format -- these days that would probably be mp4. Don't get too fancy with the properties -- don't make it 4K for instance. But depending on the frame format, go for something of a not too dissimilar size in the video format. You might need to fiddle around a little with things like frame rate, but given that most GIFs are quite short in terms of time, it shouldn't take too long to find a size and frame rate which provide an acceptable video...
jimkirk363
ram: 32GB
I have tried placing Gif files in the timeline but these do not play so no i don't think this works.
Can you make one of your GIFs available to us -- if small enough, placed here as an attachment, perhaps in a ZIP file. Or else via something like Dropbox or One Drive...
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
For animated Gif's QT is needed.
Panasonic X900m, VXF1
pepegota
motherboard: ASUS TUF Z390-Plus
processor: Intel i9 - 9900k
ram: 64 GB
Video Card: GTX 1660 6GB
sound_card: On board sound
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: Ben Q, "21" LCD
Corel programs: VS 2018, VS 2019, VS 2020
Post by pepegota »
I use video to video converter. It is old, but when written was way ahead of its time. Still good today and free.
https://www.videotovideo.org/
Regarding asik1's suggestion that you must have QT (Quicktime) on your computer, you might be aware that Apple -- who make QT -- a couple of years ago said they were no longer supporting QT for Windows because of some security hole in the QT player. However, you can still install just the codec. See viewtopic.php?f=1&t=66511&p=376409&hili ... ls#p376409
jimkirk363
ram: 32GB
I do not have Quicktime on my PC and have not used Quicktime in Many years. I do use the K-Lite Mega Codec pack though which has many codecs in it which probably include the codecs for Quicktime.
BJC
Hard_Drive_Capacity: 1TB
Corel programs: Videostudio X10 and 2020
Post by BJC »
one of the problems is that GIF's are not videos - they are an image with several different layers which are programmed to show in sequence giving the illusion of movement
I haven't tried it in the latest versions but the last time I did Videostudio just displayed a sequence of still images - which if you use a GIF editor you can manipulate - change speed etc.
what has worked for me in the past is to run the GIF while using a live screen capture programme which then gives you a true video to do what you want with
