'Because of the limitations of the specified file format (and possibly the save options you've selected), the saved file will be limited to a merged image.'
Can someone explain exactly what this means? It sounds like a bad thing but I don't really understand what its implications are? Does it deplete the quality of the saved file in any way? I know what merge means but why is it used negatively here saying the file will be limited in some way? Does it matter at all or should I just ignore it and turn the warning off?
Limited To Merged Image
Andy2011
- motherboard: Gigabyte A520M S2H
- processor: AMD Ryzen 5 PRO 4650G 6 Core CPU
- ram: 16 GB
- Video Card: Integrated Radeon Vega GPU
- sound_card: on board
- Hard_Drive_Capacity: 2500 GB
- Monitor/Display Make & Model: BENQ GW2760HS + Benq T905 as second monitor
- Corel programs: Aftershot Pro 3, Paint Shop Pro 2020
Re: Limited To Merged Image
Welcome to the forum.
Keeping it relatively simple, an image created/opened in PSP can have lots of layers - overlays, adjustements, text, drawings and so on. To save these, the it is necessary to use the pspimage format.
A jpeg file has just one layer so if the image is to be saved in that format, all the PSP layers have to be merged into one.
In a similar way, a RAW camera file may be of 14 bits per pixel but the jpeg can only be 8 bits per pixel so again an adjustment is needed.
I can't think of a case where saving in a different format affects the resolution (width and height in pixels).
Hope this helps a bit.
Knowledge is recognising that a tomato is a fruit: experience is not putting it in a fruit salad.
