Wishlist for VS 2021
Re: Wishlist for VS 2021
Unfortunately, we do not accept any language except English here. You could always use a service like Google's Translate which gives a good version of your post:
"Hello
Corel user since version x4, x7, x8, x10 etc… and now VideoStudio 2018 which works perfectly.
I recently switched to the 2020 version, but this version seems buggy and much more unstable than mine and I would even say unusable with Mercalli in xx.mpg output file.
After opening an exchange by email ref 6364269 Corel asks me to connect to my PC without telling me in return if it is having the same problems. My data is private so I refused this connection by requesting a refund for this update which is only giving me problems.
Incidentally, this problem was confirmed after installing it with a friend of mine to whom I recommended VideoStudio. He couldn't get the 2018 version (definitive working), because the 2020 version was also very unstable and unusable for DVD making."
I couldn't quite understand what you meant about your friend and VS 2018, but that does not really matter. I am also not sure your complaint should be here in this Wish List as it does not suggest anything specific.
"Hello
rcoucou
- System_Drive: D
- motherboard: Hewlett-Packard 1651 KBC Version 07.25
- processor: Hewlett-Packard
- ram: 6GB
- Video Card: intel HD Graphics Family
- sound_card: IDT High Definition Audio CODEC
- Hard_Drive_Capacity: 360
- Monitor/Display Make & Model: AU Optronics 13,9 Monitor
"Hello ken
sorry but i can read the post directly en french via google
I recently upgraded to the 2020 version, but this version seems buggy and much more unstable than mine and I would even say unusable with Mercalli as an xx.mpg output file.
opening an exchange by email ref 6364269 Corel asks me to connect to my PC without telling me in return if it has the same problems My data is private so I refused this connection by requesting a refund for this update day that only gives me problems.
Incidentally, this issue was confirmed after I installed it with a friend of mine who I recommended VideoStudio to. He couldn't get the 2018 version (which definitely works) because the 2020 version was also very unstable and unusable for DVD authoring. "
all this with the aim that the next version of corel or to have a real functional update of this software or at least to market a version which keeps the previous functionality
- HumblyDriven
Make it to where we can delete all folders. Like backgrounds, I don't use it it should be an option to delete it. Also, save as I want to set a custom folder not go straight to my projects I should be able to set a custom folder. Every time I want to save a project have to go on a mission to my fav folder. Another is LUTS it would be nice to buy some custom LUTS seeing as I can't use custom ones people made for photoshop. It would be nice if we could buy some from ya'll for other people who use the program at the home and get more screen. I'll post images also. Lastly the crashing. It's always crashing when it seems to be overworked. Hope this helps
HumblyDriven
Backgrounds, I would minimise the selection so only Backgrounds is listed, then simply ignore it.
You have created your own folders that can also have sub folders
I doubt that Corel will change this to allow us to hide, although that option was applied to some folders in past versions I think for the audio folders.
Saving VSP, yes a bit of a pain when saving NEW projects, but then where should a new project be saved to.
If you create a new empty project and save it to your folder, then when you need to start a new Project it can be opened from File, showing at the bottom of the list.
Then File Save As will allow you to give the vsp a new name and in your folder not the programs default folder.
fingerbreaker
If a custom-made mask file used in a project is moved or deleted, VS does not prompt for a re-link but rather just uses another file as a mask. Instead, VS should follow the same re-link protocol used for other missing clips: provide the filename of the original mask file and give the user the ability to browse for the clip in a different location.
fingerbreaker
The ability to query VS on the filename of a mask file used on a clip. Currently, the user can select "Blending, Mask Modes, Mask Frame" and see a list of thumbnail images representing the mask file being applied to the clip, but there is no way to identify the filename or location of the file used.
This would be useful when migrating a project to a new drive or folder since mask files cannot (currently) be re-linked by VS.
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
once you save your project as smart package the mask will followfingerbreaker wrote: ↑Wed Jan 27, 2021 9:29 pm The ability to query VS on the filename of a mask file used on a clip. Currently, the user can select "Blending, Mask Modes, Mask Frame" and see a list of thumbnail images representing the mask file being applied to the clip, but there is no way to identify the filename or location of the file used.
Panasonic X900m, VXF1
TonyP
- motherboard: Gigabtye X570 Elite
- processor: AMD Ryzen 9 5950X 16core 32threads
- ram: 32GB 3200
- Video Card: Sapphire RX 6700XT 12GB
- Hard_Drive_Capacity: 10TB
- Monitor/Display Make & Model: LG 27" IPS 4k, Acer 24" 1920x1080
- Corel programs: VS2023, PSP2023, Aftershot 3
I guess the "wish list for 2021" is now over with the release of the program.
Time to start the wish list for 2022!!
As far as i know the 2021 program has not been released as it is not available for sale on the Corel web site
and yes we will get round to creating a new wish list
TonyP
- ram: 32GB 3200
Got the email today for it from Corel. Loyalty offer.
excalibur1814
- motherboard: NUC 13
- processor: i3-1315u
- ram: 32Gb
- Video Card: Intel UHD Graphics for 13th Gen Intel Processors
- sound_card: Onboard
- Hard_Drive_Capacity: 1Tb Samsung 990
- Monitor/Display Make & Model: Samsung 49" 5120 x 1440 Pixels screen
- Corel programs: VideoStudio 2023 & PSP 2021
Time to create the new 2022 version of this thread. 2021 is HERE! WOOOOoOOo crash. Sorry, had to launch it again. Glad I saved.
