I click the "Change your view" button to toggle between list, details, thumbnail views, everything is fine
I open a sub-directory (it's empty except including another directory, as I have moved all files from it trying to figure out what is wrong)
I click the "Change your view" button to toggle between list, details, thumbnail views, result is instant crash
here's the dir structure:
D:.
├───psdfiles
└───pspimages
└───tmp
When opening pspimages and clicking change your view, it crashes. It crashes also if tmp is moved to the same level as pspimages (which is the default directory after I click "Open...") without doing anything, Instant crash.the "tmp" directory has about 20 pspimage files in it. And with tedious testing I have located the reason to the crash to one file (I can't attach it, as pspimage is not allowed). I had another constant crash before with another file, unfortunately I just got rid of the file to be able to use the program.
So it seems, all the files inside a sub-directory are red when opening a directory, is it for showing the folder thumbnail or what I don't know. But to prevent the crash in my case, required moving the offending file from the immediate sub-directory.
This is with most recent version of PSP 2020 as of today. Also the same symptom with PSP 2019.
Windows event logs are empty, no related messages there.
