Videostudio 2020 Audio Issue
Guru Larry
- motherboard: ASUS board of some type
- ram: 32gb
- Video Card: GTX 1080
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Samsung 3DTV
- Corel programs: Videostudio
Hey, Videostudio 2020 won't allow me to change the volum to any of the audio in the timeline...
I can change the actual number of the volume, but the audio still comes out at 100%. Audio ducking does help somewhat, but I can never have a consistant lower volume on anything.
Is this an actual glitch? Can I reset/turn to default any audio options Videostudio has?
Thank you!
Thank you!
TonyP
- motherboard: Gigabtye X570 Elite
- processor: AMD Ryzen 9 5950X 16core 32threads
- ram: 32GB 3200
- Video Card: Sapphire RX 6700XT 12GB
- sound_card: Realtek
- Hard_Drive_Capacity: 10TB
- Monitor/Display Make & Model: LG 27" IPS 4k, Acer 24" 1920x1080
- Corel programs: VS2023, PSP2023, Aftershot 3
Re: Videostudio 2020 Audio Issue
I have the Ultimate version, which one do you have?
I can keyframe the audio by selecting the Sound Mixer.
BJC
- Corel programs: Videostudio X10 and 2020
The effect on clips in the timeline will only be apparent if you play back in "project" mode - is that what you are doing ?
leszektrojanowski
- motherboard: Intel H670
- processor: Intel Core i7-12700 Processor
- Video Card: NVIDIA GeForce RTX 3070 8 GB GDDR6X
- sound_card: Realtek High Definition Audio Device
- Hard_Drive_Capacity: 3TB
- Corel programs: VS 2021 Ultimate
Guru Larry wrote:Hey, Videostudio 2020 won't allow me to change the volum to any of the audio in the timeline...
Thank you!
I'm having exactly the same issue. I am able to change the actual number of volume, but it makes no difference though. I even put 0 and the audio was still audible...
RobCharles1981
- motherboard: MSI MAG B650 TOMAHAWK
- processor: AMD Ryzen 7 7800X3D
- ram: 32gig DDR5
- Video Card: XFX 7800XT
- sound_card: Sound Blaster Z
- Corel programs: Studio Ultimtate 2023
I'm along the sort of same lines here as well.
I'm editing a video with separate audio recorded - I edited the audio in Audacity which all is fine.
When I enter the audio track in the program and along with the video, right at the start of the track there seems to be allot of noise right at the very start, I'm wondering if there is an issue with the "fade in" effect???
plemmens
- motherboard: Asus Z87
- processor: Core i7-4770K - 3.5GHz
- Video Card: GeForce GT640
- Monitor/Display Make & Model: 2xMedion HD
- Corel programs: PSPX8 - CVSX9 - PS19 - Aftersh
No problem here.
Tested in three different ways.
1. Add clip to timeline, rightclick and Open Options Panel, change Volume from 100 to 0, audio is muted.
Reset volume to 100
2. Rightclick clip on TL and > Audio > Adjust Volume > adjust volume from 100 to 10 > volume is adjusted accordingly.
3. Drag mp3 music clip to TL, rightclick and choose Adjust volume > change volume from 100 to say 20 > volume is adjusted accordingly.
Reset volume to 100
Paul
plemmens
OK, I now have a recipe that shows the problem.
1. Drag a clip to TL. I used a UHD mp4 clip.
2. Rightclick clip and choose Audio > Split Audio
3. Rightclick audio clip and choose Adjust Volume...
4. Change volume to 10 and click OK
5. Play clip and see (hear) it still plays with full volume.
Paul
TonyP
- ram: 32GB 3200
The reason why I said it worked for me is because it was a single clip. And it did. But cutting the clip up into smaller pieces, no matter what, the sound volume would not change no matter the sound volume settings or keyframes.
A more complete description of the problem would have helped initially giving the workflow that produced the issue. Makes diagnosing the problem much easier.....
Paul33
- motherboard: Hewlett-Packard 0A9Ch XU1 PROCESSOR
- processor: Intel Xeon E5430 2.66GHz x 2 Dual Core
- Video Card: NVIDIA GeForce GTX 1060 6GB
- Hard_Drive_Capacity: 2TB
- Monitor/Display Make & Model: BenQ GW2765
- Corel programs: VideoStudio 2020 Ultimate
I had this issue for some time until I worked out that my audio software - Sound Blaster Audigy FX - was over-riding and normalizing the volume via the "Smart volume" setting.
When I switched off "Smart Volume", I could hear all of the volume changes in VS.
TonyP
- ram: 32GB 3200
Smart Volume? Where is that located?
I am now getting mixed results. I have two clips on the timeline. I first edit the volume of the first clip with the Sound Mixer. It works. I split the clip. It still works. I add another clip, I can keyframe the audio but it doesn't work. Then it does work, I don't know any more....
I place two clips on the Video track. I split each one so now I have 6 clips. Now, I can only keyframe in 2 of the 6 clips.
For me on my computer, the feature is broken.
I suspect he may be talking about a Sound Blaster control...TonyP wrote:Smart Volume? Where is that located?
leszektrojanowski
It's all gobbledygook
Just ran a quick test
1 / add a video to the top track
2 / set audio level to 10%, play to check level as ok
3 / cut clip, now have two clips both show 10%
4 / first clip plays at full volume, second plays at 10%
That has to be wrong
We do now know of other audio issues when adding transitions or fade into a trimmed clip
I would ask that you report your findings to Corel Support
Paul33
Yes sorry, that is an option in Sound Blaster.TonyP wrote:Smart Volume? Where is that located?
A lot of audio software includes settings that will manipulate what you hear in terms of volume and will normailze that volume if you click certain options. I had a "Smart Volume" setting ticked that resulted in Videostudio volume changes appearing to do nothing when in fact the VS volume drops were being countered by the soundcard to suggest nothing was happening !
Not suggesting that is your problem ..... just throwing it out there as it WAS my problem and may help somebody somewhere !
Hello, is one of the issues not being able to add any audio level keyframes to a trimmed video track? Because it is what happens to me.lata wrote: We do now know of other audio issues when adding transitions or fade into a trimmed clip
Is here a fix to that? Re-installing maybe? Thank you!
