Hello, Does anybody know if it is possible to install Perfectly Clear SE v3.5 plugin to PsP2020
I have just upgraded from PsP 2019 to PsP 2020 and I am tryig to install the plugins by copying, where applicable, to the PsP 2020 plugin folder. This has been successful for all except for Perfectly Clear SE v3.5.
I unistalled Perfectly Clear SE v3.5 from PsP 2019 and performed a deep clean of the registry to ensure that no fragments would be left lying around to confuse the issue. I then ran PsP 2020 and selected Perfectly Clear SE v3.5 from the Plugin dropdown menu. This produced the following error:-
As this failed, I ran vcredist_x64.exe, from the PsP 2020 plugin folder, which produced the following error:-
I know that there is not any previous installation of Perfectly Clear SE v3.5 on my computer so I am now at a loss to know why it should think that there is.
So, is the Perfectly Clear SE v3.5 not compatible with PsP 2020? Or am I missing something? Any assistance or pointers would be very much appreciated.
Thank you
PsP 2020 - Installing Perfectly Clear SE v3.5 pluginin
John Owles
- ram: 8gb
- Hard_Drive_Capacity: 1tb
- Monitor/Display Make & Model: HP Laptop 17-ak0xx
- Corel programs: PsP2020,2019
Re: PsP 2020 - Installing Perfectly Clear SE v3.5 pluginin
This has already been discussed in a recent thread: viewtopic.php?p=371220#p371220 You will see there are others, including myself, going through the same as you. In my case, I bought in the end the commercial version of the full Perfectly Clear 3.9, and it works just fine both by itself and with PSP 2020.
I'll now lock this thread. Please continue any discussion in the other thread to avoid confusion.
