I am having problems running my mirror and flip scripts since the recent windows update. I am looking for help to fix this issue. I run Windows 10 and PSP X5.
I've attached screenshots of the two messages that I am receiving. Any help is greatly appreciated. Thank you! Lori
Mirror/Flip Script Error
tazzylady
- Hard_Drive_Capacity: 1 TB
- Monitor/Display Make & Model: HP w/2207h
- Corel programs: PSP X5
Reason: Removed images at request of OP
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
Re: Mirror/Flip Script Error
Do you have the layer that you are trying to perform the flip operation on visible in the layers palette? The error indicates that whatever the program is being instructed to flip is a layer or selection which contains no image data, so the program doesn't have an image or portion thereof on which to perform the operation.
JoeB
Using PSP 2019 64bit
JoeB
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
As JoeB notes the error is specific to trying to flip data that isn't there. Make sure there isn't an active selection. Selections -> Select None
Does it still give this error?
tazzylady
OMG Select None worked. I don't understand it because I did not 'select' anything..but it worked! TYSVM from the bottom of my heart for helping me so quickly and efficiently! I would like to suggest you delete this post as this artwork is copywrited and I have a licence to use it but I didnt put the copywrite information on the screen shots. Big hugs! Lori
JoeB
- ram: 8 GB
I believe that you can edit your post and delete the image attachments.
JoeB
JoeB
