Video Studio issue Nvidia GPU cards
SteveMartinUSA
- processor: i7 10875
- ram: 32GB
- Video Card: NVidia GeForce GTX 1650
- Hard_Drive_Capacity: 2TB
- Monitor/Display Make & Model: HP Pavillion 32"
- Corel programs: VideoStudio 2020 "Ultimate"
Re: Video Studio issue Nvidia GPU cards
I've been using VideoStudio for years and I do know how to use the Share options (mostly). Because I have a lot of time invested in using VS is the main reason I haven't moved away completely.... I've seen the light with Filmora, in terms of performance. There, my XPS 15 runs only around 10% at most during basic editing using NO proxy files, while VideoStudio is running 80-99% just to play the timeline or scrub (also with no proxy).
My goal in changing the proxy format is to increase the video quality during the editing experience, since the default proxy size is only 720 x 480. My monitor is QHD so you can imagine how bad a stretched out 720 x 480 video looks during the editing process. What resolution do you use for your proxies?
SoNic67:
I haven't taken a look at my BIOS on this laptop yet, but I will do that--thanks for the tip. Do you find a noticeable difference using 64GB of RAM? At the moment I'm only using 8GB, but 32GB of "Balistix" is on the way, and a 2TB Evo 870+. Another bummer is how old a new XPS seems to be in terms of multi-display options, motherboard, and GPU. I guess XPS doesn't mean the same thing it did years ago. I had to get a laptop with a touch panel so I could get out of the office after work. I can't sit here any longer...
SoNic67:
tletter
- processor: i7-3632QM
- Video Card: NVIDIA RTX 3080
- Hard_Drive_Capacity: 1TB
Fortunately we don't have to recreate proxy files one-by-one, rather simply enter Ctrl+A then right-click and select "Create Smart Proxy File" afterwhich any missing proxy files will be created in the background whilst we continue to edit our VSP.
tletter
tletter
See https://www.youtube.com/user/gripps2211SteveMartinUSA wrote:I find very few professionally made tutorials on YouTube for VideoStudio
720 x 480 proxies on a UHD monitor.SteveMartinUSA wrote:My monitor is QHD so you can imagine how bad a stretched out 720 x 480 video looks during the editing process. What resolution do you use for your proxies?
Adding more RAM above 16GB doesn't increase VS performance although it will allow you to run memory intensive programs concurrently with VS.SteveMartinUSA wrote:Do you find a noticeable difference using 64GB of RAM?
No - enter Ctrl+A then right-click and select "Create Smart Proxy File" afterwhich any missing proxy files will be created in the background.SteveMartinUSA wrote:Do you have to re-add a clip to the timeline to get a smart proxy file to create?
The proxy is for a entire source clip.SteveMartinUSA wrote:The proxy file has a "UPX" extension. It's not an MP4, so I can't tell if the file is just for the trim on the timeline or for the whole file?
No - see previous answer.SteveMartinUSA wrote:Does VS have to rebuild the proxy if I adjust the trim.....?
tletter
SoNic67
- motherboard: Dell Precision T7610
- processor: dual Intel Xeon E5-2667 V2
- ram: 64 GB
- Video Card: nVidia GTX 1080
- sound_card: SB ZxR
- Hard_Drive_Capacity: 8 TB
- Monitor/Display Make & Model: AOC U2879VF
No difference, in both my video editors (Corel and Cyberlink). I use that much RAM because I wanted to fill all the 4 channels of RAM per each CPU, for maximum memory speed. Since I have two CPU, that meant 8 memory sticks, each 8GB.SteveMartinUSA wrote: ↑Mon Sep 14, 2020 2:12 pm Do you find a noticeable difference using 64GB of RAM? At the moment I'm only using 8GB, but 32GB of "Balistix" is on the way, and a 2TB Evo 870+. Another bummer is how old a new XPS seems to be in terms of multi-display options, motherboard, and GPU. I guess XPS doesn't mean the same thing it did years ago. I had to get a laptop with a touch panel so I could get out of the office after work. I can't sit here any longer...
As for the storage speed, it's irrelevant. Either I save on my RAID5 HDD, on a SDD or on a RAM drive, the writing speed is the same. Way below what my RAID5 can deliver. You can check that on your computer too.
My workstation has an nvidia GTX1080 and I can scrub directly 4K videos without any proxy files. When I scrub 4K, the GPU Video Decode goes up to about 20-25%. If I encode in 4K, the CUDA 3D cores get used at 20%, the NVENC Ecoding block gets used also at about 25%.
SteveMartinUSA
- ram: 32GB
I'm not thrilled with the performance of the xps 9500 with it's gtx 1650 gpu. I prefer tablet style or 2 in 1 but they're even slower (on paper). But my iPad Air 3 running Lumafusion has very good performance, with no proxy files. But there I'm always trying to free up space for 4k/60fps footage.
What laptops work well for VideoStudio?
SoNic67
- ram: 64 GB
Did you look in the BIOS to see if you can disable iGPU / Optimus?
If you don't have that option, you need a laptop that has that option.
Here is a list:
http://forum.notebookreview.com/threads ... ch.813459/
"Discrete mode -> BIOS GFX set to PEG"
Here is a list:
SteveMartinUSA
- ram: 32GB
Yeah, I checked the BIOS and the XPS 9500 doesn't have that option, but the 9700 model does. The 9700 is the 17 inch XPS laptop, but it's also got a better GPU and better cooling.
SteveMartinUSA
- ram: 32GB
Tletter, the tutorials you listed are all 5+ years old, which kind of strengthens my argument of not having many good tutorials to choose from. Try searching "speed ramping videostudio 2020" and if you weed out the Time Remapping disaster that crashes consistently then you're only left with only one or two old tutorials. Compare with "speed ramping filmora 9", or other editor. I do have pretty good success with "variable speed" option though. That's definitely better than Filmora's approach of slicing the clip up and having all kinds of junk on the timeline.
Is it really possible (or enjoyable!) to edit with enough precision using a 720 x 480 proxy, like to perform accurate edits and color grading? Even the Full HD proxies I made are of such poor quality that I consider them insufficient for anything but the most basic editing--the opposite of eye candy.
What am I missing?
What am I missing?
- RobertOZ
- Hard_Drive_Capacity: 7 TB
Steve,
See if these are a bit more up to date for you,
https://learn.corel.com/video-tutorials ... 7b76e-3c2f
SteveMartinUSA
- ram: 32GB
Yes, I've seen all those tutorials from Corel--thank you. They're fast and to the point with great voices in the background, and beautiful. But if you believe what Corel shows you then you'll spend days trying to get things like Time Remapping to work, crash after crash after crash, thinking it's something you did wrong...
Independent tutorials help save you time by telling you not to bother, to use the variable speed option instead. I don't see a lot of people that dedicate themselves to VS, showing you the way (probably because they're too busy trying to get VS to work correctly). By comparison, look for RobHK on YouTube and look at all of the tutorials he's done on LumaFusion, or many others on that one. I think we've been very lenient with Corel with all the crashing and lack of performance. They're great marketers and mediocre developers.
tletter
Many of Gripps videos are perfectly relevant as the filters and effects that he explains are still part of VS. However, if you've mastered them then you're well on your way to being a VS guru so perhaps you should start making helpful tutorials for VS users.SteveMartinUSA wrote:Tletter, the tutorials you listed are all 5+ years old, which kind of strengthens my argument of not having many good tutorials to choose from.
Speed ramping/time remapping is loosely defined as the art of speeding up or slowing down your shots for the purpose of dramatic/creative effect. VS's variable speed feature appears to do just that. There are recent YT tutorials on the use of variable speed in VS, just search for them. However, even older tutorials on variable speed are still relevant as this feature hasn't changed much over the years.SteveMartinUSA wrote:Try searching "speed ramping videostudio 2020" and if you weed out the Time Remapping disaster that crashes consistently then you're only left with only one or two old tutorials.
There are many comments on this forum about VS crashing, not leveraging modern hardware, and lacking QA for new releases. The question is whether the VS's sales of new releases are declining and if so will that drive Corel to address some of these issues.SteveMartinUSA wrote:I think we've been very lenient with Corel with all the crashing and lack of performance.
tletter
SteveMartinUSA
- ram: 32GB
Good points. I'm going to try a few more Filmora tutorials, see if I can tolerate VS proxy files, etc. I do like VS but their poor QA is like a virus, wasting all of our time. I've been in the database development business for several decades now
and know the software business well. I'm pretty happy with Lumafusion except my iPad 256GB means I'm always moving things around, and the Lightning port is slow............ I should have sprung for the iPad pro with more storage. Cheers!
SteveMartinUSA
- ram: 32GB
I'm starting to try out DaVinci Resolve and it's running smoothly and making good use of the GTX 1650 video board in my XPS 9500. I'm finding TONS of good tutorials and the FREE version is more than enough...
The way I discovered DaVinci Resolve is from the many NVIDIA performance benchmarks on Adobe Premier and DaVinci Resolve... And with regard to rendering performance Resolve is reportedly faster than Premier!
- Chaz175
- motherboard: gigabyte technology bus clock 100 megahertz
- processor: amd ryzen
- ram: 16gig
- Video Card: NVIDIA GFORCE RTX 3060TI
- sound_card: NVIDIA HIGH DEF
- Hard_Drive_Capacity: 500G SSD +3TB
- Monitor/Display Make & Model: benq EW3270ZL
- Corel programs: corel studio ultimate 2020
Hello, my name is Chaz. I have been having thisGFORCE issue as well and discussing with a couple support teams. No one has a concrete answer. So I have resorted to the in motherboard graphics for now. When I purchased the new graphics card (RTX Gforce 3060ti) by recommendations to speed up process and fix freezing..rendering etc. Im sure over kill but...anyways it gives me grief in Corel studio, especially executing certain transitions I would like to use. So I have been researching any options to smoothly run my new card. Apparently their is a conflict with specs or design in the card with motherboard. I feel like I spent a large amount of money to no performance advantage. Little put out on this one. I thought an easy plug and play would be in line. Soo. I am looking for a solution as well and HOPING someone can wave the magic wand and fix all. Keep me posted as I with you to this topic.. cheers for now.
- Chaz175
- ram: 16gig
Hello, I can relate in a different issue. I wish this issue could be resolved. (Graphics card compatible) I have few transition effects freezing during execution. ( only with graphics card added). Works well with Intel CPU ).
