VideoStudio Ultimate 2019 - Transition Troubles
wcsd106
motherboard: MSI 970A-G45 MS-7693
processor: Amd Phenom II X4 955
Video Card: NVidia GeForce GTX 750 Ti 4GB
sound_card: Nvidia High Def Audio
Hard_Drive_Capacity: 6TB
Monitor/Display Make & Model: Acer P235H / Toshiba 32" (Dual Monitor Setup)
Corel programs: Videostudio Ultimate X10
Post by wcsd106 »
Hello,
I'm a long time user of VideoStudio. Ran X4 for many years, but have upgraded the past 4 years whenever the new version comes out. I'm having an issue with 2019 that's flat out giving me fits.
When I'm editing something on the main timeline and click on the A/B tab to put in a transition, videostudio is jumping to the end of the current clip. This requires me to scroll back to where that clip meets the previous clip (The exact spot I'm wanting to place a transition)
If I click off of the clip prior to clicking the transition button, it doesn't jump to the end and stays at the part of the timeline I want to place the transition in.
This is the first version of videostudio that has done this to me. The rest have stayed put whenever I hit transition.
Is there a way I can disable this or is this just the new norm?
Thanks.
Re: VideoStudio Ultimate 2019 - Transition Troubles
Hi wcsd106
Thanks for raising this issue…….
I have run through this procedure using earlier versions of Video Studio and only CVS2019 is showing this issue.
Although the cursor may move to the beginning of the clip the actual clip remains in place on the timeline allowing me to add the transition correctly.
But it is different to how earlier versions work
Can I also ask you to report this anomaly to Corel Support, if you go to Help – there is a link for Corel Support.
dxwalker
Post by dxwalker »
I have encountered the same problem. The workaround seems to be to be to select Project (instead of Clip) from the Video Track, THEN click the Transitions menu. Not intuitively obvious, but it seems to work.
