Code: Select all
Install Path: /opt/AfterShot3(64-bit)
LD_PATH: /opt/AfterShot3(64-bit)/lib:
XLIB_SKIP_ARGB_VISUALS:
I have SSE2
Loading plugins
Loading camera modules from "/opt/AfterShot3(64-bit)/supportfiles/cameras"
Loading camera modules from "/home/joelp/.AfterShot Pro 3/Cameras (64-bit)"
Bibble program arguments ("./AfterShot")
AfterShot2 Pro New key used. 20
AfterShot vers.: 3.6.0.380
Built on: "st říj 2 2019"
Language: en
App Path: /opt/AfterShot3(64-bit)/bin/AfterShot
System Home: /opt/AfterShot3(64-bit)/supportfiles
User Home: /home/joelp/.AfterShot Pro 3
Prefs Home: /home/joelp/.config/Corel/AfterShot Pro v3.conf
Platform: Linux
Issue: "Mageia release 7 (Official) for x86_64"
Kernel: "Linux version 5.4.12-desktop-1.mga7 (iurt@scwx861.mageia.org) (gcc version 8.3.1 20191101 (Mageia 8.3.1-0.20191101.1.mga7)) #1 SMP Tue Jan 14 21:14:55 UTC 2020"
Build Mode: Release
Product Name: "AfterShot Pro 3"
Registered Version
Initializing
Cpu Manager init: 4
**** Making CLManager
Got 1 platforms
OpenCL is enabled in low mem mode
platform 0x32dfa10 "NVIDIA Corporation" OpenCL Version: "OpenCL 1.2 CUDA 10.1.120"
device: 0x334c140 "GeForce GT 730"
****** Device "GeForce GT 730" enabled
LDS size 49152
Compute units: 2
Freqency: 901
Max work items: 1024
Max work item sizes: 1024 1024 64
Device OpenCL Version: OpenCL 1.2 CUDA
Device OpenCL C Version: OpenCL C 1.2
Device OpenCL Extensions: cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer
Device Memory: true
Zero Copy: false
SVM: false
LDS size 49152
Compute units: 2
Freqency: 901
Device Memory: true
Zero Copy: false
SVM: false
tileSize: 512
"MemTotal: 8097164 kB"
Memory: 3
Asset: 2147483647 purge
Heavy Asset: 2147483647 purge
NoiseEngine: 150 purge
NoiseEngine: 75 cache (50 min)
Histogram: 24 purge
Histogram: 12 cache (12 min)
PluginData: 9 purge
PluginData: 9 cache (8 min)
ImageMaster: 600 purge
ImageMaster: 300 cache (50 min)
NContainer: 2147483647 purge
Path: 2147483647 purge
Path: 2147483647 cache (2147483647 min)
RawData: 25165821 purge
UncompressedRawData: 9 purge
UncompressedRawData: 9 cache (8 min)
Version: 600 purge
Version: 300 cache (50 min)
PerfectlyClear: 6 purge
PerfectlyClear: 4 cache (4 min)
TileStack: 24 purge
TileStack: 12 cache (12 min)
StackTile: 3000 purge
Created 163 buffers of 3286400
FALLBACK to 326 tiles
BImageTile: 1800 purge
BTiledImage: 2147483647 purge
RegionImageTile: 3000 purge
Allocate Asset manager
Option group - "" - already contains an option with name - "TIFFTAG_AFMODE"
Option was not registered.
Option group - "" - already contains an option with name - "TIFFTAG_FLASHMODE"
Globals: systemhome /opt/AfterShot3(64-bit)/supportfiles
Globals: userhome /home/joelp/.AfterShot Pro 3
==================== Plugins =====================
Name:
Identifier:
Version: 1.0.0
Path:
Name: Black and White
Identifier: com.corel.BlackAndWhite
Version: 1.0.0
Path: <System Home>/plugins/Black and White.afplugin
Identifier: com.corel.equalizer
Version: 1.0.5
Path: <System Home>/plugins/Equalizer.afplugin
Code: Select all
Adding master versions
Scanning file "/home/joelp/hdd_backup/mount_dirs/Obrázky/2017-07-22 - gulase/DSC_6277.NEF"
Importing: "/home/joelp/hdd_backup/mount_dirs/Obrázky/2017-07-22 - gulase/DSC_6277.NEF"
Found XMP for /home/joelp/hdd_backup/mount_dirs/Obrázky/2017-07-22 - gulase/DSC_6277.NEF with 1 versions
Scanning file "/home/joelp/hdd_backup/mount_dirs/Obrázky/2017-07-22 - gulase/DSC_6278.NEF"
Importing: "/home/joelp/hdd_backup/mount_dirs/Obrázky/2017-07-22 - gulase/DSC_6278.NEF"
Found XMP for /home/joelp/hdd_backup/mount_dirs/Obrázky/2017-07-22 - gulase/DSC_6278.NEF with 1 versions
Scanning file "/home/joelp/hdd_backup/mount_dirs/Obrázky/2017-07-22 - gulase/DSC_6279.NEF"
Importing: "/home/joelp/hdd_backup/mount_dirs/Obrázky/2017-07-22 - gulase/DSC_6279.NEF"
Found XMP for /home/joelp/hdd_backup/mount_dirs/Obrázky/2017-07-22 - gulase/DSC_6279.NEF with 1 versions
Scanning file "/home/joelp/hdd_backup/mount_dirs/Obrázky/2017-07-22 - gulase/DSC_6280.NEF"
Importing: "/home/joelp/hdd_backup/mount_dirs/Obrázky/2017-07-22 - gulase/DSC_6280.NEF"
Found XMP for /home/joelp/hdd_backup/mount_dirs/Obrázky/2017-07-22 - gulase/DSC_6280.NEF with 1 versions
Scanning file "/home/joelp/hdd_backup/mount_dirs/Obrázky/2017-07-22 - gulase/DSC_6282.NEF"
Importing: "/home/joelp/hdd_backup/mount_dirs/Obrázky/2017-07-22 - gulase/DSC_6282.NEF"
Found XMP for /home/joelp/hdd_backup/mount_dirs/Obrázky/2017-07-22 - gulase/DSC_6282.NEF with 1 versions
Scanning file "/home/joelp/hdd_backup/mount_dirs/Obrázky/2017-07-22 - gulase/DSC_6285.NEF"
Importing: "/home/joelp/hdd_backup/mount_dirs/Obrázky/2017-07-22 - gulase/DSC_6285.NEF"
Found XMP for /home/joelp/hdd_backup/mount_dirs/Obrázky/2017-07-22 - gulase/DSC_6285.NEF with 1 versions
Scanning file "/home/joelp/hdd_backup/mount_dirs/Obrázky/2017-07-22 - gulase/DSC_6287.NEF"
Importing: "/home/joelp/hdd_backup/mount_dirs/Obrázky/2017-07-22 - gulase/DSC_6287.NEF"
Found XMP for /home/joelp/hdd_backup/mount_dirs/Obrázky/2017-07-22 - gulase/DSC_6287.NEF with 1 versions
lot of lines
"AfterShot encountered an error writing to the disk and will now close"
waiting...
doCancel
doCancel
doCancel
doCancel
doCancel
doCancel
doCancel
WaitForShutDownDialog timeout. Will probably crash now!
done waiting
Unlocking catalog: "/home/joelp/.AfterShot Pro 3/cache"
Unlocking catalog: "/home/joelp/Obrázky/AfterShot Pro Catalog 3/AfterShot Catalog 2020"
Early Cleanup
delete globals
delete globals
delete mid globals
delete done globals
delete app
Code: Select all
"BError: type = 1013, "decompressRawData cancelled" in file ../src/cameras/NefReader.cpp:1012"
Extracting RAW data: "/home/joelp/hdd_backup/mount_dirs/Obrázky/smazat/2019-05-11 - Křivonostka/DSC_9036.NEF"
Decoding RAW data: "/home/joelp/hdd_backup/mount_dirs/Obrázky/smazat/2019-05-11 - Křivonostka/DSC_9036.NEF"
Code: Select all
unable to open database file Unable to fetch row
Code: Select all
unauthorized memory access (SIGSEGV) (core dumped [memory image saved])
