Hi Jean-Luc
And thanks from me, I was not aware of the Blemish Fixer, not that I have had to fix any images like this.
The tool works very well.
I did find that the despeckle options affected the faces causing a soft focus, although was able to replace those with the original faces, several ways to do that.
Again thanks
Stray light across photograph
Jean-Luc
- Hard_Drive_Capacity: 2 Tb
Re: Stray light across photograph
If you want a better view of your work, you may create a Contrast/Brightness Adjustment Layer above the image (settings: Brightness 38, Contrast 42). But make your image corrections on the layer underneath.bxgti4x4 wrote: I will work on it over the next few days and get back to with the results.
Another tool you could also apply is Automatic Small Scratch Remover (settings: Lower 0, Upper 3, Strength Normal, Remove dark scratches unchecked, Remove light scratches checked).
Jean-Luc
I have also tested the Paint Brush tool (settings: Hardness 0, Opacity 40, Blend mode Normal and Foreground color RGB 27):
Jean-Luc
I think you mean Salt and Pepper tool (Despeckle works only on single-pixels and no settings).lata wrote:Hi Jean-Luc
Joelle
- motherboard: Asus Prime B350M-A
- processor: AMD Ryzen 5 1500 Quad-Core
- ram: 16 GB RAM
- Video Card: NVidia GeForce GTX 1050
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Samsung
- Corel programs: PaintShop Pro X9
Good work Jean-Luc!Jean-Luc wrote:I have also tested the Paint Brush tool (settings: Hardness 0, Opacity 40, Blend mode Normal and Foreground color RGB 27):
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
Jean-Luc
If you want to learn more about restoring old, damaged photos in PaintShop Pro, see this excellent tutorial from Carole Asselin:
https://www.youtube.com/watch?v=1cu2Tz3ecXo
