Bíld 144 ist unlesbar
- solarkritik
- motherboard: h8-1335ez
- processor: INTELi7-3770 CPU 3.40GHz
- ram: 8 GB
- Video Card: AMD RADEON 7570
- sound_card: AMD HighDefinition Device
- Hard_Drive_Capacity: 1000 GB
- Monitor/Display Make & Model: Two monitors: Toshiba and Benq
- Corel programs: VSX9.5 (since July 2016)
Look message at Screenshot. This message is coming at the end of rendering.
Message in englisch: "Picture 144 is unreadable"
What does it mean? I have no file with name "Bild 144" in my timeline.
- Attachments
- CorelVS_Fehler_Bild_144_ist_unlesbar.jpg (19.98 KiB) Viewed 2320 times
I'm using "VIDEOSTUDIO" since 2005: using since Ulead 5+6+7 -->> COREL VIDEO STUDIO 10+11+12+14+15+17+19+19.5+20 WIN 10
Re: Bíld 144 ist unlesbar
I have seen a simular error message which related to the image duration in frames
Do you have any images using 144 frames?
The previous error was found to be a Ntsc clip placed in a Pal timeline and had been reversed to play backwards
The program did not like that combination.
- solarkritik
- ram: 8 GB
Right, In my video is a sequence where a very short clip is played backward. But the rendering was in two former times in function with this played-backward-clip and without this message.
Searching with google about this message "Bild 144 ist unlesbar" I found this: https://www.slashcam.de/info/BILD-NR--5 ... 91531.html
He said, I have to divide the 144 frames to 25fps, so the mistake must be at 5.76 seconds. But this haven't also localized the problem.
If the clip is 144 frames and NTSC it will use 29 / 30fps and be 4.8 seconds duration.
When added to a Pal timeline it will retain its duration by removing frames, this may cause a stutter in the video.
If you can identify the clip then first converting the clip to Pal then reverse video should work ok.
- solarkritik
- ram: 8 GB
I have found the bug.
It is difficult to describe: It was an animation-feature of a CVS-FX in connection with a black-picture-video-ending.
There was a conflict.
I don't know why.
Very incredible, very difficult to describe in words.
Thanks for your help
I don't know why.
Moin, könntest Du die Lösung eventuell auf deutsch erklären?
Ich habe gerade die gleiche Fehlermeldung ...
Your post reads in English: "Moin, could you possibly explain the solution in German? I just got the same error message ..."
If you do receive a reply it will need to be in English as well as German as we have a policy requiring English to be spoken here. But Google Translate seems to do a good job.
- solarkritik
- ram: 8 GB
You have disabled "private Massages" in your Account
It's totally available for me. Just click on the "Contact: ..." part and both the email and PM become available...
Just changed that, sorry.
Sorry.Ken Berry wrote: ↑Tue Nov 23, 2021 4:34 am Your post reads in English: "Moin, could you possibly explain the solution in German? I just got the same error message ..."
