Require Expert Help Please, Creating Best Possible Image fro
ShopPaint
processor: Intel R Core TM i5 10400 CPU 290GHz
Monitor/Display Make & Model: HP S2031a
Corel programs: PaintShop Pro 2020
Re: Require Expert Help Please, Creating Best Possible Image
Post by ShopPaint »
Kathy_9 wrote:
ShopPaint wrote: Hello Kathy,
I did as you suggested and downloaded the free trial version of Topaz Denoise AI. I ran the same picture through the software using the “Auto” command (see screenshot), but the results were nowhere near as dramatic as yours. I also played about with different values but couldn’t get anywhere near your results.
What am I doing wrong? Is the trial version different to yours?
Any help or advice would be appreciated,
Peter.
The trial version and my version are the same version number.
I ran it through on Auto and there were still dots on the right side of the image so I pushed the Remove Noise slider all the way to the right and that removed the dots. That made the image very soft so I increased the Recover Details slider.
Note: you can apply the results and run it through a second time if you are not happy with the results. It's a lot of trial and error.
Hope that helps.
Thanks, Kathy, I will try it again. Jean-Luc has suggested using FFT. Do you think applying the latter prior to running the image through Topaz Denoise would be a good idea?
regards,
Pete.
ShopPaint
Post by ShopPaint »
Jean-Luc wrote:This plugin says it is compatible with PaintShop Pro but I cannot make it appear in PSP:
http://www.descreen.net/eng/soft/descre ... bility.htm
This trial version doesn't show up in mine either Jean-Luc.
ShopPaint
Post by ShopPaint »
Jean-Luc wrote:I applied another method.
I'm using the Fast Fourier Transform plugin.
FFT_July2008.zip
Extract it in the Plugins folder. Works on PSP 32bit.
Enlarge the Image's Canvas with grey. I added 44 pixels for this demonstration.
The plugin doesn't work well on image's border. Adding an empty space around the image prevents the defect.
Apply FFT plugin. The result:
Paint on the white areas. Don't touch the central area.
This damned forum doesn't accept more than 4 attachments. See next message.
Jean-Luc would i be able to use this 32 Bit Fast Fourier Transform Plugin or would i need a 64 Bit version, and if so do you know if there is a free version?
regards,
Pete.
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Post by Jean-Luc »
ShopPaint wrote: Jean-Luc would i be able to use this 32 Bit Fast Fourier Transform Plugin or would i need a 64 Bit version, and if so do you know if there is a free version?
You need to use your PSP 32bit version with the FFT plugin. The FFT plugin is not visible nor active in PSP 64bit.
It is a free version:
http://www.tipsquirrel.com/use-fft-to-reduce-texture/
Jean-Luc
Post by Jean-Luc »
ShopPaint wrote: I have well over 100 pictures to correct
Are the other images similar to the one you posted?
Removing the halftone dots with the FFT plugin must be done manually because the FFT will be different for each image. Yes, it will take time to correct all your images. Your workflow is not the best from the beginning and you will pay that during postprocessing. :(
The second part of the correction (after FFT processing) could be done with a script if all images are of the same quality.
ShopPaint
Post by ShopPaint »
Thanks for the advice Jean-Luc, it's appreciated. However, I am going to have to give this some more thought, as I need an easier solution if possible given that I have approximately 150 pictures to correct
regards,
Pete.
Andy2011
motherboard: Gigabyte A520M S2H
processor: AMD Ryzen 5 PRO 4650G 6 Core CPU
ram: 16 GB
Video Card: Integrated Radeon Vega GPU
sound_card: on board
Hard_Drive_Capacity: 2500 GB
Monitor/Display Make & Model: BENQ GW2760HS + Benq T905 as second monitor
Corel programs: Aftershot Pro 3, Paint Shop Pro 2020
Post by Andy2011 »
I have arrived a bit late at the party but I do have another couple of methods for cleaning up the dots from halftone images. In the sample picture I have used (a) Adjust\Add/Remove Noise\Moire Pattern Removal and (b) Effects\User Defined Filter. The samples use just those changes and have not been cleaned up otherwise. Both methods use averaging - as does Gaussian blur - so there is a natural loss of sharpness. For the Moire Pattern Removal, I started off with a Fine Details setting of 1 and incremented until the dots just disappeared. A setting of 3 seemed to be the best. The banding adjustment has little effect.
The User Defined Filter (UDF) is more complicated to explain. I started off using one I had put together a couple of years ago for smoothing a very differnt picture. The result was OK but I went back to basics and made up one that worked on a 5 by 5 pixel matrix, based on the halftone dots being separated by that sort of amount. Each resultant pixel is a weighted average of 25 but with stong centre weighting, the outermost pixels having just 10% to 30% of the effect of the centre pixel. (I could post the preset if it is of interest.)
A personal preference when working with old newspaper pictures is to go to black and white, ignoring the brownish colour of the paper. The original paper would probably have been white with carbon-black ink dots with the brown colour arising from oxidation of the cellulose fibres. If the output warrants an antique feel, it is easy to apply sepia toning. Of course, if a facsimile of the original newspaper picture is the objective, leave the halftone dots in as they give character!
Two types of smoothing to remove halftone dots
Knowledge is recognising that a tomato is a fruit: experience is not putting it in a fruit salad.
Jean-Luc
Post by Jean-Luc »
Andy2011 wrote: (I could post the preset if it is of interest.)
I'm interested...
Post it. :)
Andy2011
ram: 16 GB
Post by Andy2011 »
I'm interested...
I've attached a zip file as the presets are pspscripts which are not permitted as attachments. Anyone using it needs to satisfy themselves that it is benign. It needs to be saved to the presets file location - in my case ..\Documents\Corel PaintShop Pro\2020\Presets.
I have it set to work on grey values but it is easy to swap to all colour channels.
If you don't want to unzip and save the preset, the values can be typed in.
image of preset entries
User defined filters are good for all sort of effects that are a bit different from PSP built-in ones. For example, embossing can be made harder and softer.
UDF settings for embossing
Preset_UserDefinedFilter_Centre-weighted-01.zip
unzip to appropriate location
(536 Bytes) Downloaded 128 times
ShopPaint
Post by ShopPaint »
Thanks for the advice/information Andy it's appreciated. I think i might have to look at Fast Fourier Transform which would be more time consuming, but I may have no choice,
regards,
Pete.
Jean-Luc
Post by Jean-Luc »
Andy2011 wrote: I've attached a zip file as the presets are pspscripts
Thank you!
It is interesting...
:idea:
Andy2011
ram: 16 GB
Post by Andy2011 »
Jean-Luc wrote: Thank you!
:idea:
Yes, I find the UD filter concept interesting - sometimes a solution in search of a problem but I love the maths.
With them you can:
  • Emboss at various apparent depths with illumination coming from a chosen direction
    Find edges
    Blur - with weighted average, just vertical, just horizontal, just one colour channel etc.
    Shift selection or image by 1 to 5 pixels
    and so on
There is a very helpful tutorial at pspug.org (suggest searching).
Perhaps this topic warrants a 'sticky' with some examples - though only for nerds like me!
Jean-Luc
Post by Jean-Luc »
Andy2011 wrote: There is a very helpful tutorial at pspug.org (suggest searching).
Could you point me to the exact page? :)
Andy2011
ram: 16 GB
Post by Andy2011 »
Jean-Luc wrote:Could you point me to the exact page? :)
Sorry - some user boards hate full URLs as they can be malicious
http://www.pspug.org/tutorial/html/tutb ... rdefnd.htm
Jean-Luc
Post by Jean-Luc »
Hi Andy2011,
Thank you for the link. Well explained.
