Require Expert Help Please, Creating Best Possible Image fro
ShopPaint
processor: Intel R Core TM i5 10400 CPU 290GHz
Monitor/Display Make & Model: HP S2031a
Corel programs: PaintShop Pro 2020
Re: Require Expert Help Please, Creating Best Possible Image
Post by ShopPaint »
Kathy_9 wrote:This was just with Topaz Denoise AI. It's an interesting plug-in. You can download a trial and play with it and it integrates well with PSP.
https://topazlabs.com/denoise-ai/
Thanks, Kathy, much appreciated.
Just one question, what would be the difference if I used Topaz Denoise or purchased Topaz Adjust. Would the Denoise function that would be included in the Topaz Adjust software be any different, less effective?
regards,
Pete.
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Post by Jean-Luc »
If you want a "Topaz feeling", it can be made in PSP:
I applied the following on my last attempt posted before.
Highlight/Midtone/Shadow tool: Shadow 40, Midtone: 40, Highlight: -30
Adjust / Softness / Soften tool
Local Tone Mapping tool: Strenth 4
Brightness/contrast tool: Brightness 0, Contrast 15
Adjust/ Hue and Saturation / Colorize: Hue 13, Saturation 50 (sepia toning)
Adjust / Skin smoothing: Amount 50
You may record all those steps and apply them in one click on an image.
PS : I find that the Topaze plugin deforms the face: the right eyelid is drooping and the smile on the left is too long and goes up.
ShopPaint
Post by ShopPaint »
Thanks, Jean-Luc, I will definitely bare these settings in mind and i will print this version off.
I know what you mean with regards to Topaz, and when I looked at Kathy's attempt on my computer screen I noticed the same as you, but oddly enough when it is printed it is much more acceptable,
regards,
Pete.
ShopPaint
Post by ShopPaint »
Hello Jean-Luc, I have just printed your latest version and it was good, except that it is quite "soft" compared to the Topaz version. Their really is quite a difference with all these pictures when you actually print them out on paper,
regards,
Pete.
Kathy_9
Hard_Drive_Capacity: 2TB
Post by Kathy_9 »
ShopPaint wrote: Just one question, what would be the difference if I used Topaz Denoise or purchased Topaz Adjust. Would the Denoise function that would be included in the Topaz Adjust software be any different, less effective?
regards,
Pete.
I would not recommend Adjust AI for the type of work you are doing. Adjust AI is used to bring out colors and gives you control over highlights/shadows and details but is less effective at denoising. It's always best to download a free trial and see how it works for your workflow.
ShopPaint
Post by ShopPaint »
regards,
Pete.
Thanks for the help and advice Kathy, it's really appreciated,
regards,
Pete.
Jean-Luc
Post by Jean-Luc »
ShopPaint wrote:Their really is quite a difference with all these pictures when you actually print them out on paper,
What is the final print size?
ShopPaint
Post by ShopPaint »
Hello Jean-Luc, the final print size will be approximately 50mm wide by 80mm Portrait.
Jean-Luc
Post by Jean-Luc »
Mmmm... Difficult to make a better job inside PSP. We may vary some settings but I think PSP is unable to give a smooth appearance (like Topaz) without being blurred. :?
Are the other pictures similar?
ShopPaint
Post by ShopPaint »
Hello Kathy,
I did as you suggested and downloaded the free trial version of Topaz Denoise AI. I ran the same picture through the software using the “Auto” command (see screenshot), but the results were nowhere near as dramatic as yours. I also played about with different values but couldn’t get anywhere near your results.
What am I doing wrong? Is the trial version different to yours?
Any help or advice would be appreciated,
Peter.
Jean-Luc
Post by Jean-Luc »
This plugin says it is compatible with PaintShop Pro but I cannot make it appear in PSP:
http://www.descreen.net/eng/soft/descre ... bility.htm
Jean-Luc
Post by Jean-Luc »
I applied another method.
I'm using the Fast Fourier Transform plugin.
FFT_July2008.zip
(460.38 KiB) Downloaded 137 times
Extract it in the Plugins folder. Works on PSP 32bit.
Enlarge the Image's Canvas with grey. I added 44 pixels for this demonstration.
The plugin doesn't work well on image's border. Adding an empty space around the image prevents the defect.
Apply FFT plugin. The result:
Paint on the white areas. Don't touch the central area.
This damned forum doesn't accept more than 4 attachments. See next message.
Jean-Luc
Post by Jean-Luc »
Apply IFFT plugin (Inverse FFT):
The halftone dots are mostly removed and you can now enhance the image.
Kathy_9
Post by Kathy_9 »
ShopPaint wrote: Hello Kathy,
Peter.
The trial version and my version are the same version number.
I ran it through on Auto and there were still dots on the right side of the image so I pushed the Remove Noise slider all the way to the right and that removed the dots. That made the image very soft so I increased the Recover Details slider.
Note: you can apply the results and run it through a second time if you are not happy with the results. It's a lot of trial and error.
Hope that helps.
ShopPaint
Post by ShopPaint »
Jean-Luc wrote:I applied another method.
FFT_July2008.zip
Morning Jean-Luc, thank you for taking the time to try another method. I had read about FFT but hadn't tried it. Given that I have well over 100 pictures to correct I wanted to try and keep the procedure relatively simple. However, I may have to try this method and then possibly run the image through Topaz Denoise AI and see what can be achieved. I am certain we will get there in the end,
regards,
Pete.
