ASP 3 No visible thumbnail except if I click on each one
Mimu
- processor: i5 4570 CPU 3.2GHz
- ram: 4GB
- Hard_Drive_Capacity: 500GB
- Corel programs: ASP3
I just installed ASP3 on my new PC after having used ASP on my old one. Tried to use it , but no thumbnail is visible. I just have a bunch of squares and they appear only if I click on them. How can I fix it up ?
hannes_hab
- System_Drive: Z
- motherboard: ASUSTeK P8H77-I
- processor: Intel Core i7 3770K 3.5 GHz x 8
- ram: 16 GB
- Video Card: AMD Radeon R7 200 Series
- sound_card: Radeon HD 7700 7800 Sapphire
- Hard_Drive_Capacity: 2x250GbSSD
- Monitor/Display Make & Model: LG IPS 21:9 UltraWide 34UM95-P 3440x1440
- Corel programs: AfterShotPro 1, 2, (3)
Re: ASP 3 No visible thumbnail except if I click on each one
try: select all - edit - create thumbnails - there are some camera models (Panasonic and others) that have no embedded preview
<CTRL+A> and <ALT+P>
"Under File → Preferences → Import & Cache, there is an option to create
previews during import and file system browsing. Enabling this option
(it is on by default) makes browsing much faster and ensures that the
thumbnails are rendered with the AfterShot settings applied. On the
other hand, it will use most of the machine's resources during preview
generation when a folder is first visited or imported. You should leave
it on unless you are working on a machine with limited power."
hope this helps
hope this helps
regards Hannes
austria
Nikon D7000 + D70, Nikon P6000, Nikon P330 (use P7800) PanasonicTZ100, Vuescan
bibble 4, bibble 5, ASP mostly on Ubuntu 14.04 ( sometimes Suse Linux 11.4 or WIN10)
austria
Mimu
- ram: 4GB
Thanks for your answer. After getting in touch with Corel helpdesk, I loaded version 3.5 and it works OK.
