PSP 2020 Clone brush leaves marks on image
SamC
- motherboard: ECS MCP61PM-GM 2.1
- processor: 2.20 gigahertz AMD Itanium 2
- ram: 3 GB
- Video Card: none -incorporated in board
- Hard_Drive_Capacity: 1 TB
- Monitor/Display Make & Model: Dell 2000 WFP 20"
- Corel programs: PSP X7, PSP X8, PSP X9
PSP2020 clone tool leaves marks all over image as i move the cursor, until i get out of the clone tool. When i go back into the clone tool, the marks reappear as i move the cursor until i can't see my work. Pleasse help.
Jean-Luc
- Hard_Drive_Capacity: 2 Tb
Re: PSP 2020 Clone brush leaves marks on image
Could you give us more information?
- A screen capture of the defect would be nice.
- Are you in Grey mode? (black and white)
- Is your image in 16bit?
- Are you cloning inside an Adjustment layer?
Did you try a reset (launching PSP with shift key down)?
gpmatthews
- motherboard: Dell Inc. 0DT029
- processor: Intel Xeon 5120 1.86GHz
- ram: 12 GB
- Video Card: S240HL
- Hard_Drive_Capacity: 2.5TB
- Monitor/Display Make & Model: 2xAcer S240HL
- Corel programs: Paintshop Pro 2019
I have the same problem using PSP 2022 and 2023, both 32 vand 64 bit- have you found a solution? Resetting the database does not work for me.
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
This could be a re-draw issue. Does zooming in and out of the image remove the marks?
I don't think it'll work bu you could always try turning on full window redraw. File -> Preferences -> General Program Preferences.
Under "Miscellaneous" you'll see a checkbox for "Force full window redraw when positioning image elements"
gpmatthews
- ram: 12 GB
Yes, zooming in or out removes the marks, but full window redraw makes no difference to the problem.
File -> Preferences -> General Program Preference ->Display and Caching: "Use Precise Cursors" appears to have fixed the problem, at least for now. I'll continue to use this setting and see whether the fix is permanent...
gpmatthews
- ram: 12 GB
After behaving well for some time, the problem has returned. Precise cursors is not the answer.
gpmatthews
- ram: 12 GB
Kathy_9
- Hard_Drive_Capacity: 2TB
I've tried to replicate your issue but have had no luck so far.
Here's one more thing to try and eliminate by resetting the clone tool itself. Click on Presets on the Tools toolbar and then on the curved arrow as shown below.
Jean-Luc
Don't know if it could help:
Try untabbed mode:
In the top menu, click on Window / uncheck Tabbed documents
Try untabbed mode:
STEVENGARTHWAITE
- System_Drive: E
- motherboard: 0360pv a00
- processor: i5-8250u
- ram: 32GB
- Video Card: noneall
- sound_card: noneall
- Monitor/Display Make & Model: Intel UHD graphics 620 generic PnP monitor 15.
- Corel programs: PAINTSHOP PRO 2020 AND 2021 X8
I have the same problem leaving tracer marks when using Clone Tool in both PSP2020 & 2021. I think it started after a Windows Update (not sure). I've tried everything I know. I did not read any solution or did I miss it? PSP also has been changing my mouse setting?
- ram: 6 GB
With the clone brush have you tried turning off "Show Overlay"? It's once again not guaranteed to fix the issue. The problem is this is an issue with your computer and how PSP works with it. It's not a universal problem and there may not be a fix we can offer short of turning off brush outlines which isn't very helpful.
