I made topic earlier also, but now this is starting to bug me off!
PLEASE COREL, fix this, i can adjust give you information what you need
my setup is win 7 64 bit. Have had many corel psps before.
When I changed 2020 to open editor as default always, it started to not open every second time, just process is open with < 20 mb of ram reserved.
have to kill it and open again.
Really not how any app should work in the year 2020 (1995 it was still ok)
PaintShop Pro Build Information:
Build Date 7. lokakuuta 2019 @ 13:02:11
Build Mode Release (16000004)
Hardware Configuration:
OEM ID: 9
Processors 4
Processor Type Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz
MMX Support No
Memory / Drive Status:
Memory Load Index 65 %
Total Physical Memory 15,94 GB
Available Physical Memory 5,46 GB
Total Paging Memory 31,88 GB
Available Paging Memory 16,04 GB
Total Managed Memory 15 MB
Total Handles: 184
Temp Drive Free Space 334,34 GB
Video Driver Information:
Bits Per Pixel 32
Number of Colors 16777216
DIB Output 24 BPP
Palette Size Non-Paletted
Resolution 1680 x 1050
Operating System Information:
Operating System Windows 7 Service Pack 1
Plug-in Information
Filter Plug-ins Loaded: 0
Import Plug-ins Loaded: 0
Export Plug-ins Loaded: 0
Format Plug-ins Loaded: 0
DLL Name Version Load State
CmdArtistic 1571737216,00 None
CmdBase1 1574271872,00 Partial
CmdBase2 1573363072,00 None
CmdBevels 1570770816,00 None
CmdClipboard 1571057024,00 None
CmdColor 1571988352,00 None
CmdEmail 1570657664,00 None
CmdExternal 1570599296,00 None
CmdFile 1573420416,00 None
CmdGeometry 1571372928,00 None
CmdHDR 1570808704,00 None
CmdJGL 1570672000,00 None
CmdLayers 1572818816,00 None
CmdLighting 1570708480,00 None
CmdNonGraphic 1571868160,00 Partial
CmdOrganizer 1570820608,00 None
CmdPhoto 1572769792,00 None
CmdPhotoSharing 1570828288,00 None
CmdPrint 1570913280,00 None
CmdPyScript 1571043840,00 None
CmdSelections 1571440128,00 None
CmdStandard 1571422720,00 None
CmdTexture 1571057664,00 None
CmdVector 1570881536,00 None
CmdWeb 1571083264,00 None
ToolArt 1571326976,00 Partial
ToolObject 1572816384,00 None
ToolPaint 1572465152,00 None
ToolSelect 1571194880,00 None
ToolStandard 1571326464,00 None
ToolText 1571288064,00 None
ToolWarp 1571352576,00 None
WinTab Tablet Status
Driver Version: None
Corel Paint shop pro 2020 does not open
jukka
- System_Drive: B
- processor: thunderbolt
- ram: 32bmw
- Video Card: s3 triodent
- Monitor/Display Make & Model: whaat?! 4 monitors. Yup! 4
- Corel programs: psp 2020, videostudio 2019
Re: Corel Paint shop pro 2020 does not open
and the version is 22.1.0.43 x64
Glenn M
- motherboard: Asus Z97 Gamer Pro
- processor: Intel i7
- Video Card: Nvidia TRX 960
- sound_card: Realtech HD onboard sound 5-1
- Hard_Drive_Capacity: 1 TB
- Monitor/Display Make & Model: ASUS 24"
- Corel programs: PaintShop Pro 2023 Ultimate
Just so you don't feel alone, I too have this exact issue with PSP 2020 Ultimate. So far Corel has been of very little help, except to tell me to re-install and try again. I did that about a dozen times, in a dozen different ways. Then over the holidays they decided that because I hadn't responded to their request for my results (which in reality I sent to them every time they requested it), I got a message saying that since I was not responding that they closed my issue ticket. If I continue to have problems or needed assistance I could open another ticket.
I've gotten more, and better support from the forum admins and others here than from Corel. Too bad, so sad. Let me know if you have any better luck or find a solution. I will do the same.
I had the same problem. I hadn't connected my external hard drive that contained the folder that should open when PSP started. After I reconnected the hard drive, I was able to open PSP again.
compinaut
compinaut
