Strange issue with Script filter
Pepi
motherboard: ASUS TUF Z270 MARK 1
processor: Intel i7-7700K
ram: 32GB
Video Card: AMD Radeon RX 5700 XT
Corel programs: VideoStudio 2022; PaintShopPro 2022
Post by Pepi »
I had long video where I tried to add text boxes using "Script" -filter. When I did a troubleshooting it looks that this is actually proDAD's HeroglyphScript-4.0.
The video was long and I need to add multiple texts with different names. So obviously, as lazy I'm, I create one filter and then applied that to overlay. When I have done that I then copied it multiple times across video. After that I only need to do few modifications to the text and I could save time. ....or that was the idea :roll:
But I actually end to the following (a test video):
Looks fine? Yes, but the problem was, on the VideoStudio the same moment looks like this:
On the output the only first text is correct "TEST Text 01". Then rest of the text were "TEST Text 02".
If you are looking for the VideoStudio, you can see I have selected third filter and the text is "TEST Text 04".
And when I select the third box, nothing change, but when I select some other box and then select the third it looks like this:
I believe the workaround is to not copy the sections on the Overlay multiple times with filter, but copy the overlay section only without filter/effect, and then add filter one by one, which is something I don't want.
But something is still wrong on VideoStudio, it should made what it show. Anybody remember WYSIWYG (What You See Is What You Get).
VS2019
Don't Panic
Re: Strange issue with Script filter
Are you saying that when you customise the Script and modify the text that it does not change.
I did this
1 / drag a colour clip (black) to the overlay track
2 / apply a FX Script, double click and Customise the filter
3 / added my own text
4 / Insert returned to timeline with correct text
5 / right click clip for Copy, Drop to overlay track created a second clip
5a/ a second option to copy and paste attributes would also create the same Script effect.
6 / double click new clip – customise script to change the text
7 / Insert returns to timeline with second clip containing new text.
Pepi
ram: 32GB
Post by Pepi »
Yes, that is what I meant. Here is once more a new example:
Btw, with two copies I got the correct behaviour. Try with four like I did.
1. One black color on Overlay 1
2. Add script to that.
3. Do the modification
4. Accecpt all changes
5. Copy that three times.
6. Modify each of them.
How does it look your site :?:
Don't Panic
Hi Pepi
Yep using several clips does have a strange effect with the text
I will have to do more tests , I had thought it may be because of using the Colour clips but have tried Jpeg images with the same problem.
Its strange that when i move from Clip 1 to 2 then to 3 and 4 I get one type of text, yet moving down from 5,4,3,2 and 1 the text changes
It does appear that the text is applied to frame 1 of a clip yet the remaining frames have a different text
Very confusing
I also tried copy clip 1 only, to create all the clip, then i tried Clip 1 Copy - creates Clip 2, then Clip 2 Copy to create Clip 3 and so on.
So far I am unable to correct or explain why we see this problem
Pepi can you report this to Corel Support
Pepi
ram: 32GB
Post by Pepi »
lata wrote:Hi Pepi
Great to hear that, meaning again, it is only on my workstation :)
And yes I will do it, but I’m at the moment not close to my wks, so I’ll do that after few days.
Have a great New Year !!
Don't Panic
