Mask creator, limited to 59 seconds only?
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
Re: Mask creator, limited to 59 seconds only?
Why you need any sample file speeeded? take any of your 3:32:12.20 cruise mts shot and try to apply mask from 0 till 2:01:12 minutes, I couldn't.
Panasonic X900m, VXF1
I do not have any video files that length, besides i do not think the Mask Creator was designed for that length of video, although it may work given a lot of patience whilst the program restores itself from Not Respondingasik1 wrote:Why you need any sample file speeeded? take any of your 3:32:12.20 cruise mts shot and try to apply mask from 0 till 2:01:12 minutes, I couldn't.
The main problem would be the frame rate of 25fps, which as i have said is causing this problem, at least for me, using 24fps appears to work ok
So if you can render a video using the lower frame rate maybe you can confirm my findings.
asik1
- ram: 8gb
OK, the short answer even with 30fps I cant get more than 59sec and I set my VS2018 to NTSC.
I'm rendering now with ReSpeeder a 24fps file. (12% to 86sec)
- Same, 59sec is the limit.
lata wrote:
Hi Pepi
Not sure if you missed my last reply
Any video I tested using 23.976 fps were ok
All other video using 25,50, 29, 60 fps suffered the 59 second limit
Create a 23.976fps ( AKA 24fps) video and try that.
Pepi
- motherboard: ASUS TUF Z270 MARK 1
- processor: Intel i7-7700K
- ram: 32GB
- Video Card: AMD Radeon RX 5700 XT
- Corel programs: VideoStudio 2022; PaintShopPro 2022
Hi lata,lata wrote: Hi Pepi
I'm very sorry, the weekend is not here yet, so replies are slightly slower
But YES ! You nailed, you are my hero ! When the frame rate is 23.976fps, there is no problem with mask creator.
Now I need to get the support to see this also
Don't Panic
Don't Panic
Hi Pepi
I have passed the problem on to Corel from my end, but you should badger Corel Support with this one.
