..not im a Kojak and not through age but through sheer frustration thanks to this ….this.....
Prey tell me please...
I completed my little 3minute project, loads of edits and time spent. I simply clicked MP4 render ( smartrender auto. on anyway ) and waited about..25min for it to render and sure enough it works..fine.
I noticed a few things I would like to re-do though. So, my project was still on the timeline, I tweaked, and then hit Share - MP4 - Rendered ( it took quicker this time ). End result..was ok..dunno..thought I could hear a few more 'clunks' re the sound quality...but all ok.
However, I decided to alter it slightly again. Once again, my project was already sitting on the timeline. I tweaked, rendered. When I went to view the ( again fast rendering time ) project...it was ok...but then midday the screen went blank a second..like a corrupted file...few blanks on screen and then back to normal. More hair began falling out!!…. Annoying.
Why is this?
What about if I go back to one of the earlier Saves of this project...and amend what I want..and then render....will be be better quality ? less risk of this 'blankish /corrupt screen blacks out squares appears for a few seconds. WHAT IM ASKING IS, How can I ensure I do my FINAL EVER render on a project...to ensure best quality? Too late? Ive saved as I went...so...VS has 'already once rendered' my project...so all downhill from here?
I had lovely thick hair until VS came along !!
garjobo123
- processor: I7 6700
- ram: 32GB
- Video Card: GEFORCE 970
- Corel programs: CVS 2020
Re: I had lovely thick hair until VS came along !!
Can you try rendering again but from Share deselect Smart Render, does that help........
tletter
- processor: i7-3632QM
- Video Card: NVIDIA RTX 3080
- Hard_Drive_Capacity: 1TB
Ensure that your project properties match those of your video clips.garjobo123 wrote:WHAT IM ASKING IS, How can I ensure I do my FINAL EVER render on a project...to ensure best quality?
You seem to be under the impression that VS alters source clips when it edits and renders. However, VS is an NLE system that performs non-destructive editing on source material, i.e. you can edit and render a clip as many times as you like without effecting the source.garjobo123 wrote:Too late? Ive saved as I went...so...VS has 'already once rendered' my project...so all downhill from here?
VS produces audio blips in the output at times (see viewtopic.php?f=1&t=66212&start=29).garjobo123 wrote:thought I could hear a few more 'clunks' re the sound quality.
tletter
garjobo123
- ram: 32GB
Thank you for the replies, and happy to note that VS does not decrease quality re rendering.
Strange though why on the 3rd render ( as mentioned, I altered a few seconds of my short video ) the render definitely appears...hard to say...certainly that literal 'breakdown' for a second - the video literally stops - grey screen fraction of second followed by a few blocks appearing - aka..when you put in a scratched dvd to a dvd player...the type of effect. Never had that before - a bad render.
NOW - I will add...I am ( reluctantly ) using a IPAD 6 for my recordings..too late now...never a fan..but that's what I used.
SO - your saying for me to check properties...NEVER could get a grasp of that..and always assumed - Autosetup - would suffice.
Clicking on one clips;
MPEG 4
TYPE - H 264 HIGH PROFILE TYPE
ATTRIBUTES - 24BITS 1920 X 1080
FRAME RATE - 29.937 FRAMES A SECOND
DATA RATE -15976 KBPS
Audio type - mpeg AAC AUDIO
BIT RATE - 84 KBPS
ATTRIBUTES - 44100HZ 156BIT MONO
SO - anything special about above? How to alter settings?
MPEG 4
BIT RATE - 84 KBPS
Pepi
- motherboard: ASUS TUF Z270 MARK 1
- processor: Intel i7-7700K
- ram: 32GB
- Video Card: AMD Radeon RX 5700 XT
- Corel programs: VideoStudio 2022; PaintShopPro 2022
One case at a time..
I have never seen black screen without explanation. So the first questin is, go back to VS: can see the same black screen on preview? I personally have always found the black screens on there. And please select "project" on the preview, not the clip: Can you test the same using some alternative video file? Can you still see the same issues?garjobo123 wrote:....but then midday the screen went blank a second..like a corrupted file...few blanks on screen and then back to normal....
Don't Panic
Don't Panic
