Detail Enhancement Script Bundle
njm-sd
- Hard_Drive_Capacity: San Diego
Purchased the Detail Enhancement Script Bundle for use with PSP 2020 Pro and ran it using the Corel provided install program. The installer said "setup has finished installing Detail Enhance Script Bundle Pack." In PSP, I opened the script toolbar and looked for the scripts in the listing but don't see anything that looks like the light, medium heavy, or extreme enhancement scripts. How do I locate the scripts? Is there a step I'm missing?
theavy
- motherboard: Dell 0CNDTP A00
- processor: Intel Core i7-9750H
- Video Card: NVIDIA GeForce RTX 2060 6GB
- sound_card: NVIDIA Virtual Audio Device Wave Extensible WDM
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Generic PnP Monitor (17.1"vis)
- Corel programs: PSP X9 thru 2022 - VS 2020, 2021, 2023
Re: Detail Enhancement Script Bundle
In the 'Select Script' dropdown, select 'Detail Enhance', you should see them listed there.
njm-sd
In the 'Select Script' dropdown, 'Detail Enhance' is NOT one of my choices. Reloaded the bundle from My Library and restarted PSP. Nothing changed. Still cannot locate the scripts.
theavy
I checked both versions of 2020, and noticed that 'Detail Enhance' only shows in the 32bit version.
If you want the scripts to also appear in the 64bit version, you can copy the 'Detail Enhance' folder from the C:\Program Files (x86)\Corel\Corel PaintShop Pro 2020\Languages\EN\Scripts-Restricted to the
C:\Program Files\Corel\Corel PaintShop Pro 2020 (64-bit)\Languages\EN\Scripts-Restricted folder.
In checking further on my system, I found that the installer had added the 'Detail Enhance' folder to the Scripts Restricted folder under PSP 2018, not PSP 2020. Not sure how or why that happened.
njm-sd
Its now working. Corel Support sent me a link to the file and I downloaded it and installed it. That fixed the problem. Thank you for working with me on this.
