Does VS support 480 x 720p (portrait) frames?
Djard007
motherboard: Asus P6T
processor: Pentium quad core
ram: 24 GB
Video Card: ATI All-in-Wonder HD
sound_card: Onboard Dolby 7.1
Hard_Drive_Capacity: 8 TB
Monitor/Display Make & Model: Dual Samsung 23" LED
Corel programs: Video Studio X10.5, PaintShop Pro X8
Post by Djard007 »
I edited an MP4 video clip with a frame size of 480 x 720p (portrait) and wish to save it with the same properties. I tried every option, including Custom; but the "User-defined" setting is grayed. Any way to get version X10 to save the file with the frame size of the original?
Djard007
Corel VS Ultimate X10.5
Corel PSP Ultimate X8
Win 10 Pro (x64), 24 GB RAM, 8TB HDD
Dual Samsung 23" monitors
BJC
Hard_Drive_Capacity: 1TB
Corel programs: Videostudio X10 and 2020
Re: Does VS support 480 x 720p (portrait) frames?
Post by BJC »
Sounds to me as though you are choosing the wrong options in the 'Share' panel - can you not select the Mobile Devices options as I have shown in my image which is for X10.5 - your profile says you have X10.5 although your signature doesn't
Djard007
ram: 24 GB
Post by Djard007 »
Thanks for responding. I updated my profile but version X10.5 does not appear in the post...maybe in the next post.
Your screenshot is 720x480 (DAR: 1.50:1), not 480x720 (0.667:1) that I have, which is not widescreen but portrait orientation, not uncommon on YouTube. Very disappointing if VS does not support such a common frame size. But surely I am overlooking something.
Djard007
Djard007
ram: 24 GB
Post by Djard007 »
Problem solved, thanks to Trevor. Below are the steps I successfully used. Compression must be disabled before "User-defined" is functional.
1. Share tab -> AVI (or MOV) as custom frame sizes are limited to these two file formats, even in current version (12/19).
2. Create Custom Profile ("+" icon at right of "Properties" panel) -> type in a name; e.g.:
DV(480x720,30fps)
3. AVI tab -> set as follows...
~ Compression: None
~ Data type: 24-Bit RGB
~ Audio Format: PCM
~ Attribute: 48000 kHz, 16 Bit, Stereo
4. General tab -> set, for example, as follows...
~ Data track: Audio & Video
~ Frame rate: 30 fps
~ Frame type: Frame-based (allows scrolling picture by picture, aka progressive).
~ User-defined: 480x720
5. OK.
6. Dance around the room!
Djard007
