This sounds so bizarre, but I love using the lighten button to erase loads of stuff like backgrounds etc., It replaces everything with white.
Now it just doesn't work. I have Corel Paint shop Pro 2020, and it worked yesterday. Any help would be great, as I need to alter loads of photos, but can't!!!
I have tried ticking/unticking Stroke, Continuous, Mode, but to no avail. It does say L when I click on it so just don't know.
Cheers
Terry
My Lighten/Darken Tool no longer works
Re: My Lighten/Darken Tool no longer works
You probably need to reset PSP to factory default settings: Close PSP. Then hold down the Shift key when you click on the desktop icon for PSP. You will be asked if you want to reset.
Make sure you save any customized workspaces you might have made as they will be lost in the reset, but you can restore them after resetting.
patara
- motherboard: ASUS Prime Z690 DDR5
- processor: Intel i7-12700K CPU 12 Core
- ram: 32 GB
- Video Card: GeForce GTX 1060 GI Gaming 6G
- sound_card: VIA High Definition Audio
- Hard_Drive_Capacity: 1TB SSD +22TB Hard Drives
- Monitor/Display Make & Model: Dell U2715H
- Corel programs: PSP7 to PSP 2023
Terry perhaps your PSP updated to the latest version.nowipowi wrote:This sounds so bizarre, but I love using the lighten button to erase loads of stuff like backgrounds etc., It replaces everything with white.
Cheers
Terry
It is noted in the following thread on 30th October that the brush is not working correctly after the latest update.
viewtopic.php?f=56&t=66159
You are a life saver. All ok now - I just reset everything to factory default settings, tried the Lighten/Darken Tool, and YES, it worked.
Thanks a lot
Cheers Terry
Thanks a lot
Cheers Terry
