VIDEOSTUDIO X19 FILE MISMATCH .MOV
LBRESLOW
- ram: 8gigs
- Hard_Drive_Capacity: 960 gigs
- Monitor/Display Make & Model: hp W2408H
- Corel programs: X9 X10 2018
CANNOT OPEN .MOV FILE IN VIDEOSTUDIO X19. PLEASE ADVISE. KEEP GETTING FILE MISMATCH ERROR. THANK YOU.
LBRESLOW
- ram: 8gigs
Re: VIDEOSTUDIO X19 FILE MISMATCH .MOV
Yes, I have Quicktime, but to my knowledge Quicktime doesn't interact with Videostudio x19. Please advise. I am looking to add some video to an existing project in x10. The video is .mov files and cannot impost it into my library without an error saying that its a mismatched format. What is your advise? Thank you. SORRY I PREVIOUSLY INDICATED I WAS WORKING IN X19, I AM WORKING IN X10. MY MISTAKE.
LBRESLOW
- ram: 8gigs
I did more research about your question and this is what I found: the format is: Apple PRORES, 422, 1440x1080 millions. But I don't know what that means in relationship to my importing it into x10. It doesn't look like it's compatible based on this information (see below copy). However I had this video in my project before I moved the project to a new computer, which is the problem I am having now...Thanks for your help...
Section 1: Importing .MOV files
Below is a list of the video codecs with the accompanying audio codec used in Quicktime .MOV files that were tested and import into Studio 12.1 and higher.
Note: These video/audio codec combinations are paired together. It is not a "mix and match" system, meaning that the audio codec listed next to the video codec is for a single file type.
Video Codec + Audio Codec Import Combinations
Video Audio
AVC1 MP4A
MPG4 MP4A
MPG4 uLaw
MJPG PCM
MJPG uLaw
H264 MP4A (Aiptek)
Video Audio
AVC1 MP4A
MPG4 MP4A
MPG4 uLaw
MJPG PCM
MJPG uLaw
H264 MP4A (Aiptek)
