VideoStudio Pro 2019 Crashes during export
blitzpulse
Post by blitzpulse »
Hello, so I've had videostudio pro 2019 for over a month now, and all my time using it has been spent on one large project which is now finished and just needs to be exported. However, when I try to export it, it just stops at 5%. The program doesn't crash, the export window with the progress bar simply closes and nothing comes from it. I've tried exporting as an mp4 (for it's going to be a youtube video), and exporting matching project settings with the same result. I did the remote support with Corell last night for the better part of 4 hours and they were no help at all.
Has anyone else experienced this? I'm not getting any error messages or codes so I can't share those. My video and audio files come from multiple sources, my phone, my computer capture, a usb Mic, etc. And my project is roughly an hour long. I've searched the forum and haven't found any solutions or work-arounds. I just want to have my project completed.
gewb
motherboard: MSI Pro B550-VC
processor: AMD Ryzen 7 5700X
Video Card: ASRock Radeon RX 6650 XT
Monitor/Display Make & Model: LG 24MK430
Corel programs: 2018, 2021, 2023 Ult.
Re: VideoStudio Pro 2019 Crashes during export
Post by gewb »
Change to the Storyboard View as every element will be shown and easily seen. Timeline View compresses each element, especially transitions so it is easy to miss something that might be amiss, especially the dreaded gaps!
Go thru each element - does it belong? Is it the element you wanted? Are you trying to stack miultiple effects at the same time?
This is where I would start my investigation.
tletter
processor: i7-3632QM
Video Card: NVIDIA RTX 3080
Hard_Drive_Capacity: 1TB
Post by tletter »
blitzpulse wrote: one large project which is now finished and just needs to be exported. However, when I try to export it, it just stops at 5%.
Likely the reason that your rendering stops at 5% is that there is a clip there that VS doesn't like. Locate that clip and try converting it to another video format and then add it back to your VSP timeline.
tletter
RobertOZ
Hard_Drive_Capacity: 7 TB
Post by RobertOZ »
You could also try removing video clips, text and everything else around the 5% mark, save with a new name so that the original remains intact, then try rendering and exporting the revised version, if you can, then that will indicate a corruption that you need to identify in the original
blitzpulse
Thank you, I will try these suggestions when I get some time!
zaphodikus
motherboard: ROG-X570-F-Asus
processor: AMD 3950 - 16 core
ram: 64Gb
Video Card: AMD RX 6700
Hard_Drive_Capacity: M2 1TB
Monitor/Display Make & Model: 4K BenQ
Corel programs: VS 2023 Ultimate, Painter 2020
Post by zaphodikus »
I just had a export do a CTD, no error messages, the application just terminated.
Is there a possibility the devs can force a save just before the export starts? Sicne it does not autosave during an export even if you set the timer for 2 minutes, it just doesn't autosave again.
deadpixel
motherboard: Asus ROG STRIX Z370-H Gaming
processor: Intel i7 8700K
Video Card: Nvidia GTX 1660Super
sound_card: onboard realtek
Hard_Drive_Capacity: 9TB
Monitor/Display Make & Model: HP LP2465
Corel programs: Paintshop Pro 2020 - Video studio 2019
Post by deadpixel »
just a silly idea.
disable HARDWARE encoding, i have the same problem here, after disabling the hardware encoder (cuda in my case) i could render my project.
yes, CPU skyrockets but it worked for me.
zaphodikus
ram: 64Gb
Curious, I had hardware encoding disabled, and I enabled it in the last few days, and it made very little difference to stability, but since the CPU load does not change hugely for me, and most of my crashes are during rendering, I've turned HW acceleration off again.
zaphodikus
ram: 64Gb
I enabled the "Enable Smart Proxy" and pointed it to a empty folder on my SSD. Since that, I have had no crashes - I have also turned on Hardware acceleration encode and decode turned too now.
Happy bunny.
