hi,
since I installed psp2020, it does not save my keyboard assignments, like all other versions before.
when I remove "Shift+V" from new level, to assign it to paste as picture, and close PSP2020 and restart it,
the keyboard assignments are back to default.
I tried everything, reinstalled PSP2020... used the cleanup utility... nothing helps
PSP2020 does not save keyboard assignments
krazykenny
- motherboard: ASROCK Z370M PRO4
- processor: Intel i7 9700k
- Video Card: Geforce
- sound_card: Onboard
- Monitor/Display Make & Model: Acer 24"
- Corel programs: Corel PSP
jjangfree
- motherboard: ASUS P8P67 B3
- processor: I5-2500K 4.0 over
- Video Card: GT240
- Corel programs: XI, X9, 2020
Re: PSP2020 does not save keyboard assignments
Same here after 2020 update1 installed. I've no choice but to revert to 20.0.0.132
krazykenny
I am back to 2019 Ultimate...
- keyboard assigments work
- PSP 2019 starts much more faster than 2020
- hartpaul
- ram: 8 Gb
After a bit of testing assigning a keyboard shortcut sticks up to PSP 2019.
With PSP 2020 when you have assigned the keyboard shortcuts, you must then save your customised workspace and after starting PSP 2020 anew you must reload that customised workspace to have your customised shortcut keys working. This is either a new "feature" like the terrible change to the crop tool or a bug.
- ehume
- motherboard: Gigabyte GA-Z87X-UD4H
- processor: i7 4770k
- Video Card: Intel HD4600 [iGPU]
- sound_card: no_sound_card
- Hard_Drive_Capacity: 512GB+4TB
- Monitor/Display Make & Model: Acer KN242HYL
- Corel programs: PSP 2018 32b & 64b, AS3 64b, PE5 64b
If it is not corrected, should it go on the 'wish list?'hartpaul wrote:After a bit of testing assigning a keyboard shortcut sticks up to PSP 2019.
With PSP 2020 when you have assigned the keyboard shortcuts, you must then save your customised workspace and after starting PSP 2020 anew you must reload that customised workspace to have your customised shorrtcut keys working. This is either a new "feature" like the terrible change to the crop tool or a bug.
Cassel
- ram: 16Gb
- Corel programs: PSP 8 (JASC) to PSP 2023
It has been documented as a bug now.
Cassel
https://scrapbookcampus.com
Nena
- motherboard: Dell Inc 0HHV7N
- processor: Intel Xeon W-2223
- ram: 32 GB
- Video Card: NVIDIA T600
- Hard_Drive_Capacity: SSD 950GB
- Monitor/Display Make & Model: DELL U2722D
- Corel programs: Paint Shop Pro 2019
PSP2020 shortcuts
A very serious problem for me: PSP2020 Ultimate does not keep the keyboard shortcuts I configured.
While the program is open, shortcuts work, but if I close and reopen, the shortcuts no longer work. I've tried it all the way, saved Workspace of 2020, reseted and also uninstalled and reinstalled the program without success.
The PSP2020 is being completely useless to me, as I've been used to shortcuts for a long time. I bought, installed and can not use, I returned to PSP2019, with my shortcuts set up once and always working.
I already looked for updates, there is only one update, but when I try to run I get the information that my program is updated and the installation closes.
Any help will be most welcome!
Hugs, Nena
Hugs, Nena
