Automated saved project files
grayfox
- ram: 16gb
- Hard_Drive_Capacity: 1000Gbssd
- Corel programs: Studio Ultimate 9.5 and 2019
Where are these files stored, my studio 9.5 is set to save every 5mins but it has not been saving for past 1.1/2 hrs if it saves my named file. Does it save it elsewhere under a different name? I can’t find anything anywhere.
Re: Automated saved project files
Your best option is to use CTRL + S to save your project at regular intervals
The Automated save option creates a new VSP used to recover the project after a crash saved here:-
C:\Users\User Name\AppData\Roaming\Ulead Systems\Corel VideoStudio Pro (x64)\23.0\AutoSaveFolder
This folder is deleted / removed when closing the program, however a crash will keep this folder allowing us to choose to use when launching the program.
After running the program the AutoSaveFolder will be available after the Automatic Save Interval has elapsed
BJC
- Hard_Drive_Capacity: 1TB
- Corel programs: Videostudio X10 and 2020
but the auto save does not save to your current manual saved .vsp so do not expect to see revised times on your manual saved project due to Autosave - you must still do as Trevor says and manually save regularly
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
There aren't "files" only one file that is overwritten with each "autosave". Once a crash was made, on your next run of VS this file will be loaded and you better save that VSP under a new name.grayfox wrote:Where are these files stored, my studio 9.5 is set to save every 5mins but it has not been saving for past 1.1/2 hrs if it saves my named file. Does it save it elsewhere under a different name? I can’t find anything anywhere.
Panasonic X900m, VXF1
grayfox
- ram: 16gb
Thank you everyone for your help.
Much appreciated.
Much appreciated.
