video studio 2019 overlay question.
deadpixel
- motherboard: Asus ROG STRIX Z370-H Gaming
- processor: Intel i7 8700K
- Video Card: Nvidia GTX 1660Super
- sound_card: onboard realtek
- Hard_Drive_Capacity: 9TB
- Monitor/Display Make & Model: HP LP2465
- Corel programs: Paintshop Pro 2020 - Video studio 2019
ok, not sure ifthe subject is correct.
Currently i am using a trial version, this is what i want to do, not sure if it works with the 2019 version.
In psp 2020 there is a option called photo blend, where u can load photo's and combine scenery as one element.
i wonder if video studio 2019 can do the same ,blend videos ,recorded on a fix point, in my case a 360 degree video, and blend in element of a seconds, or third ! video ,and combine it as one.
BJC
- Hard_Drive_Capacity: 1TB
- Corel programs: Videostudio X10 and 2020
Re: video studio 2019 overlay question.
basically yes - but using video is not as easy as still images - would be ideal if the videos you want to blend in had a plain background because then you could put them in the overlay and apply Chroma Key (often referred to as Green Screen) and the background would vanish leaving only the main object
however if you want to pick just one item from within a bunch of others then you may have to learn how to use the video mask creator (part of Videostudio) to make a mask which moves as the object moves in the overlay video
if your blended objects have a plain background then this is the effect of using Chroma Key
deadpixel
well, the 360 camera is fixed position, becouse the camera is seeing all, on the the actor is changing position and does not cross path with the main actor
so the background is fixed.
but i guess video studio 2019 is difrent from X10 version ?
BJC
Yes of course 2019 is different to X10 that was just an old picture I used to demonstrate - you can use the same procedure in VS2019 which is why I just used the older photo if you couldn't do it in 2019 I would not of suggested it
But if showing an X10 photo confuses you - here is another image showing it done in VS2019
deadpixel
thnxs,,
still toying with VS2019 (trial) ,i need to be sure that i buy the proper video editor software for what i want to do.
you have seen those nice vids made with the people in it talking to them self ,wel i know it is made with several video sequences ,that is what i want to do ,but than in 360 style (videos are edited in equrectangular viewpoint)
asik1
- motherboard: H170M-E D3
- processor: i5-6600
- ram: 8gb
- Video Card: GTX1050-2GB
deadpixel, I don't recall any member here that work 360, so if you after specific option (in any NLE) you must continue looking for the right person.
Panasonic X900m, VXF1
Hi deadpixel
Video Studio works in a simular way to PSP.
Where psp uses layers, VS uses overlay tracks, effectively video or image clips are stacked together.
Psp views the layers from the top, so erasing part of the top layer will reveal the lower layer
VS can do the same but working from bottom to top
Erase part of the bottom overlay track reveals the track above.
We can do that by using the Mask Creator and as the backgrounds are identical the joins will be seamless
I assume you have a few recording taken with the same background, can you provide a screen shot (jpeg) of those recordings
that may help us understand a little better
Does the trial have the Mask Creator.?
deadpixel
Lata, yes, it has the mask creator.
didnt worked with it yet.
BJC
BJC wrote: however if you want to pick just one item from within a bunch of others then you may have to learn how to use the video mask creator (part of Videostudio) to make a mask which moves as the object moves in the overlay video
we were here 2 days ago
deadpixel
here is a picture, atm i am toying with masks, so, work in progress, and BJC, yes, learning more and with the hour.lata wrote:Hi deadpixel
picture is a grab from a video i made, well, several where i stand a few feet away from me and waving to the camera,getting it slowly here with the masking
