Cropping an image into multiple images
Kevin at Phoenix
motherboard: ASUS G10AJ
processor: Intel Core i7-4790 CPU 3.60GHz 8 CPUs
ram: 16384MB
Video Card: NVIDIA GeForce RTX 2060
sound_card: none installed
Hard_Drive_Capacity: 24 TB
Monitor/Display Make & Model: ASUS 27"
Corel programs: paintshop pro 2020
Post by Kevin at Phoenix »
Thanks in Advance.
I am new to Paintshop Pro 2020.
what I am trying to do is take a sheet of counters (for a board game) they are 9 columns and 10 rows. each counter is 60 pixels x 60 pixels. Is there a command or way to use the crop command to "cut" each counter out and make it a separate image?
Can this be a batch command?
an example of the sheets I am trying to 'cut' up.
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Re: Cropping an image into multiple images
Post by Jean-Luc »
Display the Grid with the following settings:
Use the Crop tool. Set its size in pixels. Drag it on the Grid. It will snap to each square.
You only need to click on "Crop as New Image":
Kevin at Phoenix
ram: 16384MB
Thanks! that makes it a lot easier.
That leads to the question is three a way to to automate cutting out all the grids as separate graphics?
Jean-Luc
Post by Jean-Luc »
Kevin at Phoenix wrote:Thanks! that makes it a lot easier.
Go to
File / Export / Image Slicer
When you Save in a folder, you will retrieve in that folder the separate graphics:
Kevin at Phoenix
ram: 16384MB
You have my undying thanks!!!
