Does ctrl-p cause PSP to crash?
ehume
processor: i7 4770k
sound_card: no_sound_card
Post by ehume »
I have an installation of PSP 2018. I have developed a problem with it. Ctrl-P or Menu > File > Print... causes PSP to crash. I can still print by goin to Menu > File > Print Layout..., dragging my image to the window and printing it. So, have any of you had a similar problem with PSP? Or is this just my setup?
BTW -- I did a shift-start (because I always save my workspaces). After the shift-start the ctrl-p still crashes PSP.
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Re: Does ctrl-p cause PSP to crash?
Post by hartpaul »
No crashing here with Canon IP4700. Gives same dialog as File > Print.
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Post by Jean-Luc »
ehume wrote: Ctrl-P or Menu > File > Print... causes PSP to crash.
It doesn't on my side.
Does it crash when the printer is not connected?
Suggestion: uninstall the printer and reinstall. It may be a printer driver problem.
ehume
processor: i7 4770k
Post by ehume »
Thanks to you all. I'll try a different printer.
Edit: Nope. I changed the printer to a Microsoft PDF printer. Very interesting. It crashed in two stages. In the first, the Print setup dialog failed to initialize but -- just once -- it showed a printer dialog. It no longer does this, but it looks for a solution twice, then asks me to close the program twice.
Jean-Luc
Post by Jean-Luc »
I think the crash will not occur when you print via the Print Layout function.
Could you confirm?
ehume
processor: i7 4770k
Post by ehume »
Jean-Luc wrote:I think the crash will not occur when you print via the Print Layout function.
Could you confirm?
Yes. This is the work-around.
ehume
processor: i7 4770k
Post by ehume »
I tried 32-bit PSP. The same ctrl-p closure occurs. I tried 64-bit PSPx9: same failure. I tried 32-bit PSPx9. Success! I circled back to try 64-bit PSPx9 again. Success. Huh? I tried 32-bit and 64-bit PSP 2018 again. Same failure. So I now have to employ the workaround only with PSP 2018.
ehume
processor: i7 4770k
Post by ehume »
Interesting: when ctrl-p fails, I get a message saying, "The Print dialog failed to initialize. If this problem persists, contact tech support. You may also try the Print Layout feature as an alternative." Turns out, that is exactly what I was using as a workaround. Seems Corel has seen this problem before. Q: is it worth contacting tech support?
Jean-Luc
Post by Jean-Luc »
ehume wrote: Q: is it worth contacting tech support?
They will not produce a patch for a previous version.
ehume
processor: i7 4770k
Post by ehume »
Granted. I still contacted them with copies of my posts.
Jean-Luc
Post by Jean-Luc »
ehume wrote: Granted. I still contacted them with copies of my posts.
If I remember, they have corrected it with PSP 2019 but not sure.
ehume
processor: i7 4770k
Post by ehume »
I wish to report a positive experience with Corel Tech Support.
I wrote to Corel Tech Support to request assistance with my ctrl-p problem. Radhika Nijalingappa stuck with me. He made a couple of suggestions that did not work, but escalated in intrusiveness, thus eschewing the big hammer until it was really needed. Finally, he sent me a cleanup tool and a replacement Ultimate file. I ran the cleanup tool, then tried reinstalling PSP. I ran into Error 1303 twice: it said the installer had insufficient privileges to access the directory of c:\Program Files\Corel\Corel PaintShop Pro 2018 (64-bit). I exited the first time and tried running the installation app as an administrator (my account is already an administrator account but sometimes apps need that extra push). It failed again.
I then remembered something from this forum: a restart. I restarted my machine, and then ran the installer normally. Everything worked!
There were just two points he needed to include in the directions:
1. The old customizations (including --- especially including – the C:\ProgramData files, which contain all of our saved brushes, etc.) are wiped out. They should be saved elsewhere for reuse.
2. Restart after using the cleanup file and before running the install file.
Of the apps not reinstalled, they still exist in my Windows X directory. The Perfectly Clear plugin was not present, but running the Perfectly Clear installation app reinstalled it.
So: as bad as we have learned to expect Corel phone support to be, writing to Corel tech support got me somewhere.
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
Always nice when a support person not only does what we hope and expect, but when somebody gives that person credit for it!
JoeB
Using PSP 2019 64bit
