[HELP] Lighten/darken brush stopped working correctly
ehume
processor: i7 4770k
sound_card: no_sound_card
Re: [HELP] Lighten/darken brush stopped working correctly
Post by ehume »
Have you tried submitting a ticket in writing? I got good service the two times I have contacted Tech Support over the years, but I read nothing but bad experiences with phone support.
patara
motherboard: ASUS Prime Z690 DDR5
processor: Intel i7-12700K CPU 12 Core
ram: 32 GB
Video Card: GeForce GTX 1060 GI Gaming 6G
sound_card: VIA High Definition Audio
Hard_Drive_Capacity: 1TB SSD +22TB Hard Drives
Monitor/Display Make & Model: Dell U2715H
Corel programs: PSP7 to PSP 2023
Post by patara »
Botta wrote:I tried this and I think the results are really good, thank you very much for the suggestion. Even if this is a workaround it's still a more valid solution than the actual support offered me.
Your welcome. Although I said it could be a workaround, it is a better process as non destructive and it is how I usually dodge and burn.
Another non destructive way of doing it is to use Curve Adjustments and then paint in light and dark with a white brush on the masks.
e.g. Add a Curves Adjustment to the image and alter the curve to darken the image and name it Burn. Then use Layers/Inverse Mask Adjustment to Invert the Mask from white to black to hide the effect.
Next add another Curves Adjustment and alter the curve to lighten the image and name it Dodge. Then use Layers/Inverse Mask Adjustment to Invert the Mask from white to black to hide the effect.
Now with both masks as black and hiding the curve effects, paint on either mask with a white brush to bring in darkness or lightness to the image.
You can adjust the opacity of the brush and also use layer opacity on the masks.
marq101
motherboard: MSI H110 ECO
processor: Intel Core i7-6700
Corel programs: PSP 2019-2023 ultimate
Post by marq101 »
Same problem here!
