After some experimentation trying to figure out why my DVD's were suffering from sound synch problems, I determined the following...
I found that if I used the Enhance Movie option to lower the volume of the video it threw it out of synch. I've no idea why, but I wondered if it was because it was a "virtual" change to the movie and was proving so resource hungry that my PC couldn't keep the image and sound together.
The video in question was about an hour long, but the sound was slipping only 20 minutes into it.
Anyway, I've lowered the "Line In" level to reduce the volume that way; I can now edit, add chapters and menus then burn to DVD and the results are perfect!
So: Ulead, why does this happen, is it a PC resource issue?
Lowering volume using Enhance Video messes up audio synch
maddrummer3301
No. Any digital processing is just "number crunching". As long as you don't get an "out of memory" error, processing power should only affect the amount of time it takes to process. (The lack of processing power can be an issue for real-time analog capture, and for playback.)...is it a PC resource issue?
I suspect a corrupt video file.
Because the audio & video are (usually) multiplexed together, corruption or a glitch won't cause sync problems until the audio & video are de-multiplexed and re-multiplexed. In order to process the audio, tha A/V have to be de-multiplexed.
De-multiplexing & remultiplexing is usually required during rendering too. So, it is very common for everything to look (and sound) OK 'till the DVD is burned, and then sync problems suddenly appear.
jedi-jae
No, sorry to clarify, the sound goes off synch before I burn to DVD.
I capture a video to my PC using MF4 - sound and image are in synch.
I edit the video and add chapter points - sound and image are in synch.
The video is a bit loud, so I go to Enhance Video and use the Audio option to lower the volume - sound is now out of synch with image, this is in preview mode, on the first screen of the process where I can jump to any point and press play to watch the video.
If I continue the process, add a menu then go to the "proper" preview screen where you have the remote control to jump chapter and test everything, the sound and image are out of synch.
It is the volume adjust option in the Enhance Video section that causes the synchronisation to break.
jedi-jae
