rotate text query
arbee
rotate text query
Post by arbee »
I know how to rotate text round a circle or globe but how do you rotate the text around the 'equator' of the globe?
DPainter
motherboard: Gigabyte
processor: Intel i7-7700 3.6GHz Quad core 8
Video Card: nVidia GTX 1070
Hard_Drive_Capacity: 2T HDD
Monitor/Display Make & Model: 2 X SAMSUNG/s
Corel programs: Paintshop Pro 2019 Ultimate.
Re: rotate text query
Post by DPainter »
use the pen tool to draw a cured line along the equator in vector. Much the same as your doing with the circle shape to go around the globe, then set text to that line.
If the text is on the underside on the line (upside down) go back to the pen line with the pen tool, right click on a node, a drop down will open, go to Edit, Reverse contour. This will reverse the direction off the nodes and automatically put the text to the top off the line, right way up.
You can do the same thing with a circle made by the shapes tool. As a vector use the pen tool to reverse the nodes can either have text inside or outside the circle. This good when you get around to the bottom off the circle, can change the text so it's not upside down on the bottom off the circle. Note; To change the text from top to bottom as described the vector must be a second one. = One for the top (right side up). One for the bottom half with reversed contour so the text is inside the circle but up the right way. Enlarge the circle till the text is outside the Globe or circle you laying text around.
Sorry tried putting a picture description up but this sight is living in the dark ages and has to many restriction. Small shots are worthless if you can't see (read) what you need to see.
arbee
Post by arbee »
Thanks for replying. I can do what you say which is bending round the globe but the text is not moving round the globe it is static.
DPainter
Post by DPainter »
arbee wrote:Thanks for replying. I can do what you say which is bending round the globe but the text is not moving round the globe it is static.
You want it to be animated? Moving? No idea. never used animation in PSP.
jorgensen
operating_system: Windows 8.1
Post by jorgensen »
