Hi there,
Im pretty new to this and this is not my favorite language but i have one question.
in this Video:
https://www.youtube.com/watch?v=xhVxosIBzGs&t=306s
at 2.35 is an effect and i want to know is there a workaround for VideoStudio 2019 Ultimate?
Thanks for your help.
Greetings
Sven
Object Isolation
Svensalabim
- processor: Ryzen 5
- ram: 16GB DDr4
- Video Card: 1060 6GB
- Hard_Drive_Capacity: Witten
BJC
- Hard_Drive_Capacity: 1TB
- Corel programs: Videostudio X10 and 2020
Re: Object Isolation
you can get that effect by making full use of all the functions inside 'Customise Motion'
Svensalabim
- ram: 16GB DDr4
Thanks for your reply.BJC wrote:you can get that effect by making full use of all the functions inside 'Customise Motion'
With this solution i have to work it our frame per frame right?
So there (now) is no solution to mark a spot and say VideoStudio hold it here hold it there ... also right ?
greetings from germany
Sven
BJC
No you do not have to do it frame by frame - just set keyframes at the extent of each movement (mark a spot here and there if you like ) in the customise motion module and that will automatically add all the frames between the extent to give a smooth motion
