Zantara wrote:
So what's the numberthing about then?
Hi Guys
The GM or original release version was 22.0.0.132
This version requires the Service Patch which takes the version to 22.1.0.34.
If you download the files again using the original Web Installer aka Stub from Corel will download and install the latest version as 22.1.0.43 so no Service Patch would be required.
Purchases for the Ultimate PSP from Humble Bundle appears to have a number 22.1.0.44
It was confirmed by Eric Lin below, that this version is identical to 22.1.0.43
From Eric
“22.1.0.44
This is the patch1 updated version of Ultimate PSP indeed.
However ...... actually the number should not be the same as PSP pro (22.1.0.43)
There's no difference but only the installed source version.
Sorry for the confusion.
If you really care about this number difference, you could un-install the 22.1.0.44 version ==> execute the install file of PSP ultimate version; the build number then would be the same.
The fix/ enhance content is all the same between 22.1.0.44 and 22.1.0.43.”
