I do have a post on the 22nd about my capture problem and have been in contact with tech support. I am wondering if anyone else (still) uses a Canopus ADVC110? I (They are not sure exactly what the problem is, which I had not encountered before. It will capture for a around 30 secs or so stop then after a few seconds crash the program. I have been using it for quite a while and several versions without any trouble. I am curious if anyone has the same or similar device. The last contact with support said "Once again we did some research on it and we found that this is one of those odd cameras that can either be a tape or digital.If you have your videos stored on a memory card, then you need to import via windows or PlayMemories and not via VideoStudio. Once you imported to the the files to the computer, then import in the VideoStudio."
Do not get me wrong I find VS tech service professional and great to work with, not hearing back from my previous post I thought I might ask a different question to try and isolate the problem, or try something new. Already did the uninstall and clean install. Cleaned Cache, temp files, I think that covers it.
Appreciate any suggestions that I could try. The NVIDIA card is up to date as it gets, though there are more updates for other versions? Geoforce GT 640. Also change the driver for the IEEE with no luck.
The only bad questions are the ones not asked
