terrypin wrote:Looking for some eye-catching text I found this in my archives:
I like the effect and reproduced it the first time I tried. But I'm darned if I could do it again! I tried in both PSP 8 and 2018. Could someone reassure me that they can do it at least twice please?
I suppose I should raise my next point in the Scripts section, but does anyone have an up-to-date source of scripts for text effects please? Most of those I tried based on my ancient notes no longer exist.
I didn't try using your steps, but it is easy enough to do in PSP using the Shadow Tool.
1. Make vector text and select Create Raster Selection and Promote to Layer OR Create Floating Text on new layer.
2. Apply Drop Shadow - Black - Offset V 3, Offset H -3, Opacity 100, Blur 0. OK
3. Apply Drop Shadow - White - Offset V -3, Offset H 3, Opacity 100, Blur 0. OK
4. Select None.
Using an offset of 3 gave me a similar result to yours.
I prefer to do my shadows on a new layer so I can then edit them.
Here is my result compared to yours
Re Text Effects, there is an old 32 bit Plugin for Text Effects called TextArt from Plugin Creativity.
It still works in newer versions of PSP 32 bit. Was retail, but now free.
http://www.plugincreativity.net/products/text-art.shtml
TextArt
Create and customise hundreds of special effects to any text in any font. From simple outlines, contours and stripes to polished chrome, gold and steel. It even provides semi-transparent effects such as glass and mist.
Just select the area you want to contain your text, type the title or headline into the dialog and then apply one of over 350 special effects. Use the preset styles or change the colours to suit.
Over 130 new effects in v2 include Scribbles, Patches, Spangles and many more.
Plus the new Custom option lets you use your own images as textures or alpha channels to create unique effects.
