VS2018 stopped working when trying to open a VSP from 2008
RickMen
motherboard: Gigabyte B660M GAMING AC DDR4
processor: Intel i7-12700F
Video Card: NVIDIA GeForce GT 730
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 500GB M2 PCIe NVMe SDD
Monitor/Display Make & Model: Philips 246V5 24inch wide LCD
Corel programs: VS2022 Ultimate, VS2018 Ultimate
Post by RickMen »
I'm trying to open a project I created back in 2008 (I can't recall which version of VS I used to create the project with back then) but VS2018 can't open the project, VS2018 crashes and I get a windows error message saying "Corel VideoStudio has Stopped working". Any suggestions on how I can open the old project?
For the VSP file I'm trying to open under Open->Info the version = 7
Event Viewer has the following error:
Faulting application name: vstudio.exe, version: 21.2.0.113, time stamp: 0x5ab3ef12
Faulting module name: HerDocdll.dll, version: 21.2.0.113, time stamp: 0x5ab3e652
Exception code: 0xc0000005
Fault offset: 0x00000000000ebefe
Faulting process ID: 0xae8
Faulting application start time: 0x01d57e1fb8569bb3
Faulting application path: C:\Program Files\Corel\Corel VideoStudio 2018\vstudio.exe
Faulting module path: C:\Program Files\Corel\Corel VideoStudio 2018\HerDocdll.dll
Report ID: fea40f45-ea12-11e9-8357-fcaa1465b1c5
Faulting package full name:
Faulting package-relative application ID:
Sony FDR-AX53, JVC Everio GZ-HD40
tletter
processor: i7-3632QM
Video Card: NVIDIA RTX 3080
Hard_Drive_Capacity: 1TB
Re: VS2018 stopped working when trying to open a VSP from 20
Post by tletter »
RickMen wrote:Any suggestions on how I can open the old project?
Reinstall the version used to create it and try to open it. You could also post your VSP and let those with older versions of VS try to open it.
This is why some users don't uninstall old versions of VS as there is no guarantee that a newer version of VS can open a VSP created by an older version of VS.
tletter
RobertOZ
Hard_Drive_Capacity: 7 TB
Post by RobertOZ »
Your original VSP would have been created as 32 bit, VS2018 is 64 bit, so your may need to contact Support to ask the question, Can VS 2018 open a 32bit .vsp file
Also your original file will probably include filters and apps. no longer available in VS, SmartSound for example
Davidk
ram: 16Gb
Hard_Drive_Capacity: 6Tb
Post by Davidk »
This is the reason I use a work-practice of including the VS version used to create a vsp in the vsp file name, eg project_2018.vsp. And usually in my experience, a vsp failing to open means that altho it may have been created with an older version of VS, it was modified by a later one and saved without using the "save as with version type" criteria. In this case as an example, created by X7, modified/saved by 2019, it will fail to open in 2018 because it is now a 2019 vsp regardless of when/how it was originally created..
That said, several things seem unclear in your statement of problem:
- clarify this please:
RickMen wrote:For the VSP file I'm trying to open under Open->Info the version = 7
- I can find no way to get that result on any of my vsp's (back to X5 originals)
- your profile includes a 64bit OS - and I assume that also means you use the 64bit version of VS, which only became available with the release of X7 in 2014. For X6 and prior, it was all 32bit files. So the "version = 7" message would fit that. However, how Robert concludes that the failing vsp is a 32bit version eludes me. So maybe both of you could clarify how you got the version=7 message, and how that lead to (as opposed to assumed) a use of 32bits for the original file platform.
tletter
Post by tletter »
RobertOZ wrote:Your original VSP would have been created as 32 bit, VS2018 is 64 bit, so your may need to contact Support to ask the question, Can VS 2018 open a 32bit .vsp file
Normally 32-bit and 64-bit refers to the application and not its data files.
tletter
RobertOZ
Post by RobertOZ »
tletter
That's why I said,"Ask the question"
canuck
operating_system: Windows 8.1
Post by canuck »
Rickmen states he created the VSP in 2008 which would have been Corel VideoStudio Pro X2 (v12) and certainly a 32bit program.
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
David, :roll:
Panasonic X900m, VXF1
tletter
Post by tletter »
RobertOZ wrote:That's why I said,"Ask the question"
Sorry to upset you as I thought that you wanted an answer.
tletter
RobertOZ
Post by RobertOZ »
Your post did not upset me, why should it, with a .vsp created in 2008 there are too many variables which can affect its suitability to be opened in 2018, firstly what original filters/transitions/graphics etc have been used which are no longer available, is there any 16 bit data within the 2008 program, (which is a possibility back then)16 bit cannot be used with 64 bit, so the only way to obtain a definitive answer is to ask support
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
Robert, you are optimistic that "support" in 2019 will know/care about anything from 2008
RickMen
Post by RickMen »
Reinstall the version used to create it and try to open it...
tletter
I don't have the software for that version anymore.
Thanks RobertOZ, but my experiences with 'Support' have never been helpful.
Davidk wrote:.... And usually in my experience, a vsp failing to open means that altho it may have been created with an older version of VS, it was modified by a later one and saved without using the "save as with version type" criteria. In this case as an example, created by X7, modified/saved by 2019, it will fail to open in 2018 because it is now a 2019 vsp regardless of when/how it was originally created...
Thanks Davidk but the project file is original and untouched/unmodified since I first created it back in 2008.
Davidk wrote: That said, several things seem unclear in your statement of problem:
Asik1 beat me to the punch.
"Too many variables" :roll: ...I guess I'm going to have to go to the raw clips and try to re-construct the project.
Thanks Guys for all the feedback and tips, appreciate it.
Hi RickMen
Can you zip and attach the VSP, we can try to open with other versions of video studio, the oldest program I have installed is X7, UVS 7 was a long time ago.
Asik may have X9 32 bit version installed.
Your best option would be to install that older version, your serial number will be saved to your Corel account.
And can you tell us which version you were using?
The last time I had VS 12 aka X2 installed I did have many problems using the program, that was running Windows 10 Your profile shows windows 8 is that correct.
I think you will be very lucky to open the project using the latest versions of Video Studio.
Davidk
ram: 16Gb
Post by Davidk »
Confused . . .
Problem: can't open vsp in 2018. But to get the project properties as outlined you would have to be able to do that. The version and other detail isn't available in the explorer method.
Quite possibly the problem is that it opens/loads, but when played crashes 2018??
RickMen
Post by RickMen »
lata wrote:Hi RickMen
The VSP was created using VS 7 SE. VS7 was preinstalled on the desktop I purchased at the time, I don't have the software/hardware for VS7 anymore.
I'm currently on Win 8.1
Davidk wrote:Confused . . .
As soon as I click the 'Open' button on the dialog box it crashes immediately, I don't even get to play it.
