no burner exists?
vivid_maniac
no burner exists?
Post by vivid_maniac »
I cannot get my projects to burn in VS9 or MF4 now. They've been working for months but when I go to burn it says no burner exists! The burner is working fine for everything else (nero, WMP etc). I checked it in device manager and it says it is working fine. Any ideas?
THoff
Post by THoff »
Did you install any new software or drivers, or make any configuration changes?
vivid_maniac
I reinstalled the dvd drive update for MF4 and it ended up working. I don't know what happened but obviously something happened so the drive was not supported. Thanks
AnimeChick
Post by AnimeChick »
Check and make sure Nero's Drag to Disc program is not running in the background.
THoff
Post by THoff »
Nero's DLA utility is called InCD. Roxio's is called Drag To Disk. Both will interfere with other burning applications, but neither would cause the drive to not show up in Videostudio.
