How do I change a rectangle image to 4 sided polygon
jparnold
motherboard: Gigabyte Z390 UD
ram: 16GB DDR3
Post by jparnold »
Can someone advise is there a method using PSP8 to change an image which is a rectangle to one which is a four sided POLYGON (unequal opposite sides).
For example change a rectangle with a size of 200mm X 600mm to a polygon with the top 600 mm, bottom 650mm, left side 200, right side 250mm.
It would be really great if there was a tool which did the opposite of the perspective correction tool.
John a
ehume
processor: i7 4770k
sound_card: no_sound_card
Re: How do I change a rectangle image to 4 sided polygon
Post by ehume »
"Perspective Correction" tool might be the easiest way. You can also use the Pick tool in Free (Shift + Control) mode.
jparnold
ram: 16GB DDR3
Post by jparnold »
Thanks for the information.
Silly me didn't give a thought to using the 'perspective correction' tool to actually expand on one side.
Also I have no idea what the PICK tool was useful for and after you mentioned it I 'googled' it and found the following web site which 'opened my eyes' to it's use I mean the name Pick isn't as inuitive as 'persepctive correction' -
http://product.corel.com/help/PaintShop ... ingle=true
John a
