VS X10 Crashing
Mist001
motherboard: Gigabyte 970A-DS3P R2
processor: AMD Phenom II X4 830 OC 3_20Ghz
ram: 24GB
Video Card: 2047MB NVIDIA GeForce GT 1030
sound_card: Creative Soundblaster Audigy 5RX
Hard_Drive_Capacity: 1TB SSD
Monitor/Display Make & Model: Dell ST2220L
Corel programs: VS Ultimate 2020, PSP Pro 2021.
VS X10 Crashing
Post by Mist001 »
I just installed a MS update, August 30, 2019—KB4512941 (OS Build 18362.329) to be specific last night and now VS X10 crashes as soon as I add Colour Fixer Plus to the MP4 video loaded into my timeline. I realise that this is a pretty new MS update and not everyone will have it so I don't expect any solutions here, it's just a heads up. I'm going to play around and see what else doesn't work now!
MS.
gewb
motherboard: MSI Pro B550-VC
processor: AMD Ryzen 7 5700X
Video Card: ASRock Radeon RX 6650 XT
Monitor/Display Make & Model: LG 24MK430
Corel programs: 2018, 2021, 2023 Ult.
Re: VS X10 Crashing
Post by gewb »
Thanks for the heads up.
How I hate Windows 10. Will activate the update blocker ASAP.
Mist001
ram: 24GB
Re: VS X10 Crashing
Post by Mist001 »
Found the fix for me. Before this latest update, I used to take a video file from my camera, load it into VS, edit it, add effects and so on, then render it, et voila! That was it. What I've discovered is that I can take a video file from my camera, load it into VS and then render it into a new file. I can edit, add effects and so to this new file without any problem. It's just the original file that makes VS crash, although it didn't before. This may be a solution if anyone else experiences problems.
MS.
canuck
operating_system: Windows 8.1
Re: VS X10 Crashing
Post by canuck »
Does this happen with every file from your camera? What are the properties of the file from the camera and waht are the properties of the rendered file?
Mist001
ram: 24GB
Re: VS X10 Crashing
Post by Mist001 »
Using Mediainfo, the video file properties from my camera are:
Complete name : I:\DCIM\102_PANA\P1020008.MP4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/avc1)
File size : 39.7 MiB
Duration : 16 s 200 ms
Overall bit rate : 20.6 Mb/s
Encoded date : UTC 2019-09-02 00:05:04
Tagged date : UTC 2019-09-02 00:05:04
PANA : DMC-TZ57
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4
Format settings : 1 Ref Frames
Format settings, CABAC : No
Format settings, Reference : 1 frame
Format settings, GOP : M=1, N=15
Muxing mode : Container profile=Baseline@4.0
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate : 20.4 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.393
Stream size : 39.4 MiB (99%)
Language : English
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Codec configuration box : avcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Source duration : 16 s 128 ms
Bit rate mode : Constant
Nominal bit rate : 128 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Source stream size : 252 KiB (1%)
Language : English
mdhd_Duration : 16200
As for saving, I'm just using the standard VS MPEG-4 template:
MPEG-4 Files
24 bits, 1920 x 1080, 25 fps
Frame-based
H.264 High Profile Video: 15000 Kbps
48000 Hz, 16 Bit, Stereo
MPEG AAC Audio: 192 Kbps
MS.
Re: VS X10 Crashing
The video appears to be using MP42 codec
I had not heard of this so did a google which seems to indicate being one of the original MP4 ( Version2 ) and used before MP4 was standardised
Not sure how true that may be.
The fix was to convert the video file to another video file, of course MP4 H264 would do which I believe you also found as a fix.
Mpeg-4 was originally developed from Mov, one trick would be to rename the video files extension to use Mov, works sometimes……….
Corel knowledge base does recommend installing the codec pack K-Lite when having issues with HD video
You could try that, at least It may avoid the video conversions?
Mist001
ram: 24GB
Re: VS X10 Crashing
Post by Mist001 »
I have K-Lite installed. Like I said, it only happened after installing the latest update so maybe MS have reassigned a different codec or something. It's fixed for me now but if other people encounter the problem, they know what it is now.
MS.
