[Sticky] -- How to Stop Ad Popups?
Locked
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
The notifications area ads can be turned off in the same place as the regular ads. Help -> Message Preferences
You should see "keep me informed" and "Automatically download" checkboxes. And a dropdown for showing ads in the notifications area.
If you don't see that third option, and only if you don't see that third option. Close PSP and open it back up with the same administrator account as you used to install it. (right-click run as administrator) Even if you are already on the administrator account keep in mind Windows runs all programs in decreased permissions.
TwoRails
motherboard: Asus P8P67
processor: i7-2600
Video Card: GeForce GTX 560 Ti
sound_card: RealTek
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: View Sonic P220f
Re: How to Stop Ad Popups?
Post by TwoRails »
Sadly, I don't have those options in X6. What I have is below. What else can I try?
PSP X6 Help Menu.jpg (25.82 KiB) Viewed 68812 times
ram: 6 GB
Ah, PSPx6 must still have been using the Corel Guide then. I don't remember the details but here is an old knowledge base article on it.
https://support.corel.com/hc/en-us/arti ... ntShop-Pro
flagpole
motherboard: Gigabyte B450 AORUS ELITE DDR4 USB 3.1 RGB
processor: Ryzen 2600
Video Card: RTX 2060
sound_card: on board
Hard_Drive_Capacity: 6.5TB
Monitor/Display Make & Model: Iiyama 27"
Post by flagpole »
TwoRails wrote:Well... I guess I spoke to soon. I just fired up the computer and I'm still getting the popup ads.
Any ideas?
Disable all the tasks from corel in the task scheduler. Or delete/rename the target of the task. (called CUH.exe, typically located in C:\Program Files (x86)\Corel\CUH\v2\)
It may reoccur if you have cause to reinstall or repair, perhaps a service pack.
we need something pinned about this because it's asked every other day.
And Corel, seriously, you think people, or your paying customers, as they are also known, want something that displays ads when they're not even running the app? It's beyond ridiculous. To me this is simply adware.
TripleHeinz
motherboard: Gigabyte GA-B85N-WIFI
processor: Intel Core i3-4330 [3.5 Ghz]
ram: 4 GB
Video Card: nVidia GeForce GTX 750 Ti [EVGA 02G-P4-3751-KR]
sound_card: Realtek ALC898
Hard_Drive_Capacity: 960GB
Monitor/Display Make & Model: LG E2360 [1920x1080p]
Corel programs: PSP (7, 9, X5, X7), VS (X7)
Post by TripleHeinz »
Althought I haven't tried this myself, this is what Corel has published in their Knowledge Base for pre PSPX9:
https://support.corel.com/hc/en-us/arti ... 2433607#p1
To turn off or reduce the frequency of these messages, follow these steps:
1. Right-click the Corel Update Helper tray icon to open the Context menu.
2. Change the frequency of the updates or select “Never” in the “Check new updates” menu.
UPDATE: I just tried the above BUT..."There is no tray icon when the popup shows!!!". That's not fair play.
trueme
Post by trueme »
This may help... copy and paste the following to a .reg file. Double click it and let it make these registry changes...
Windows Registry Editor Version 5.00
[HKEY_USERS\.DEFAULT\Software\Corel\CUH\Current Version]
"Communication"="disabled"
[Software\Microsoft\Windows\CurrentVersion\Run]
"Corel Update Helper"=-
"ParticleShop Update Helper"=-
Kathy_9
Post by Kathy_9 »
There was a very lengthy topic on how to stop ad popups that was at least 4 pages long that I have consolidated here without the posts discussing the merits of the ads and leaving just the solutions recommended by the forum users.
You can delete the contents of the message folder or. . .
Another suggestion from LeviFiction was to delete the Messages folder with PSP closed, creating a new one and making it read only.
Message folders can be found at C:\Program Data\Corel and C:\Users\[Your Name]\AppData\Roaming\Corel.
For those interested the original topic can be found here viewtopic.php?f=56&t=62216
Kathy_9
Re: [Sticky] -- How to Stop Ad Popups?
Post by Kathy_9 »
Also See Corel Knowledge Base Article: https://support.corel.com/hc/en-us/arti ... nts-Popups
Kathy_9
Post by Kathy_9 »
arturox wrote: Wed Nov 30, 2022 10:16 am One of the things I did recently that seems so far, to keep the upgrade popups away...
Here the Messages folder contains two numeric named sub folders (One each for the two Corel PSP versions I have installed) each with a "messages.policy" file.
Instead of deleting the Messages, which immediately return after using PSP, I opened the Message.policy file in a text editor and changed the default Value= string... From value="opt-in" to value="opt-out" and so far No popups.
Locked
