Delete Additional File Locations from Registry
Eugbug
- Hard_Drive_Capacity: 1TB
Since Windows updated on my system, PSP makes folders for brushes, tubes etc on my desktop. Deleting these folders from "File locations" in preferences and saving, doesn't rectify the problem. Will deleting all the DirName2, DirName3 and DirName4 keys from the registry rectify this issue? Has anyone tried doing this? I don't really want to reset PSB to the default install state because of the hassle of having to customise all the toolbar buttons again.
STEM tutorials, "How to" guides on DIY and tools, gardening etc - http://eugbug.hubpages.com/
- ehume
- motherboard: Gigabyte GA-Z87X-UD4H
- processor: i7 4770k
- Video Card: Intel HD4600 [iGPU]
- sound_card: no_sound_card
- Hard_Drive_Capacity: 512GB+4TB
- Monitor/Display Make & Model: Acer KN242HYL
- Corel programs: PSP 2018 32b & 64b, AS3 64b, PE5 64b
Re: Delete Additional File Locations from Registry
PSP7 -- under the File item on the main menu -- has a selection for Workspace. You can save your current workspace. Best you save it as a named workspace. Look to see where the program is saving the file and write that down. Close PSP7, find the file and copy it to your desktop. You can safely reset the app to the default state because you can retrieve your saved workspace. I only had you copy it to the desktop in case you uninstall PSP. That way you always have your customizations.
Eugbug
I'm trying to reset PSP by pressing CTRL and ALT immediately after launching it, but this doesn't appear to work.
Kathy_9
- Hard_Drive_Capacity: 2TB
You need to hold those keys down while launching PSP; not after you launch it. See if that makes the difference.
Also, please update your email address as your topic notifications are bouncing back to the server as "address couldn't be found or is unable to receive email."
Eugbug
When I hold down both keys when launching, it just shows the properties dialog, with no option to reset anything.
Eugbug
The properties dialog appeared when I double clicked my desktop icon for PSP with CTRL & ALT held down. So I tried running the application from the menu instead with the keys held and that worked fine. I deleted the registry settings and loaded my old workspace settings and it's back to normal now.
