Final 2 minutes missing after final render
Chippy 68
processor: Intel Core i7-6700HQ 2.60Hz
Corel programs: Videostudio X10
Post by Chippy 68 »
I have been working on my brother-in-laws wedding video using vs10. The completed movie is just over 42mins but when I render the file the final movie doesn't include the last about 90 seconds? Have tried 3 times now with the same result.
The clips are .mts files, 1920x1080, Data rate 10533kbps, Total bitrate 10789kbps, frame rate 25fs.
I was not sure which profile would be best for the mts files but went for mpeg 4 .
Any help much appreciated, thanks.
tletter
processor: i7-3632QM
Video Card: NVIDIA RTX 3080
Hard_Drive_Capacity: 1TB
Re: Final 2 minutes missing after final render
Post by tletter »
Chippy 68 wrote:I render the file the final movie doesn't include the last about 90 seconds?
1. Can you rendered the final 90 secs on their own?
2. What is the final file size of your rendered video?
3. If you're rendering to a FAT32 volume, then the maximum file size is 4 GB.
tletter
Chippy 68
Post by Chippy 68 »
Thanks - the final file size is 3.99GB which I guess points to the direction of point 2 - on checking the usb stick is 32 bit.
Update - I have rendered to computer and last 90 secs are there - would you have any ideas how I could get the file 4.09GB to them?
canuck
operating_system: Windows 8.1
Post by canuck »
Chippy 68 wrote:Thanks - the final file size is 3.99GB which I guess points to the direction of point 2 - on checking the usb stick is 32 bit.
You have 3 options
1- trim 90 seconds or more from the video which should not have much effect on the final result
2- split the video into 2 files which will then fit on the USB stick
3- reformat the USB as NTFS
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
lower the data rate to 9800k
Panasonic X900m, VXF1
tletter
Post by tletter »
Chippy 68 wrote:would you have any ideas how I could get the file 4.09GB to them?
1. Use exFAT as it's optimized for flash drives and will allow you to store files much larger than the 4 GB allowed by FAT32 and it's more widely-compatible than NTFS.
2. If you want to keep the FAT32, then lower the bit rate whilst rendering.
tletter
Chippy 68
Post by Chippy 68 »
Thanks for the advice I'm looking into the best course of action
