I have PSP7 and am wondering if there is a plugin or software to make the white rectangle in the bottom pic fit to the curve of the cylinder. Also to do the same thing with text
I know how to curve it in the top pic.
curve to cylinder help
Re: curve to cylinder help
Not really tried to curve the panel
But if you can do with the top image, assuming the top image is 3 times taller, then rotate by 90 degrees would that be what you are after?
Not really because if I have text on the label it would be vertical.
Thanks for responding
Jean-Luc
- Hard_Drive_Capacity: 2 Tb
How do you do it in PSP7?arbee wrote: I know how to curve it in the top pic.
Apply the text after rotating the image.
You can use Effects - Geometric effects – Cylinder Vertical or Horizontal may give the impression of text on a curved surface.
Wouldn’t the text be on its side when placed on the lower can?
I sort of got it. I cropped the text into 3 sections and used the geometric effects/ skew on each the top and bottom thirds to get the shape.
Jean-Luc
Don't remember if PSP 7 has the Mesh Warp Tool.
If yes, this can be done:
- Increase Canvas size to add some space around the label (screen capture Original).
- Mesh Warp tool and deform the horizontal center to the right (see screen capture Step 1).
- Mesh Warp tool with modified Mesh vertical and deform upper and lower label edge to the left (screen capture Step 2).
Thaks Jean-Luc. unfortunately PSP7 doesn't have mesh warp tool.
Jean-Luc
Perhaps a plugin? (mesh warp plugin)arbee wrote:Thaks Jean-Luc. unfortunately PSP7 doesn't have mesh warp tool.
I'm not expert in plugins but maybe someone here knows a plugin that can do this job??
- ehume
- motherboard: Gigabyte GA-Z87X-UD4H
- processor: i7 4770k
- Video Card: Intel HD4600 [iGPU]
- sound_card: no_sound_card
- Hard_Drive_Capacity: 512GB+4TB
- Monitor/Display Make & Model: Acer KN242HYL
- Corel programs: PSP 2018 32b & 64b, AS3 64b, PE5 64b
The way to do this may be to first turn the can so that the circular parts are at top and bottom. Then PSP7 can, I believe, shape text to curves. Giving the bottom of the text some padding or moving the text block upward will be a choice OP makes. OP will end by laying the completed can down on its side.
