resizing image
agoodphoto
Corel programs: PSP2021
resizing image
Post by agoodphoto »
I went to use the filter to remove noise. I also wanted the jpeg artifact to be removed. After the operation, the file size of image was increased which is not good. The image is 6040 x 4040 and 31.5 mp's. I can not have it any more than 25 mp's. By how much do I need to reduce the size?
ehume
processor: i7 4770k
sound_card: no_sound_card
Re: resizing image
Post by ehume »
agoodphoto wrote:I went to use the filter to remove noise. I also wanted the jpeg artifact to be removed. After the operation, the file size of image was increased which is not good. The image is 6040 x 4040 and 31.5 mp's. I can not have it any more than 25 mp's. By how much do I need to reduce the size?
25/31.5=0.79 and a little, so you have to reduce your image 21%, I think, 79% of the original size.
agoodphoto
Re: resizing image
thank you, that helped.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: resizing image
Post by LeviFiction »
You don't need to resize your image, just use Save As and set the compression until it reaches the size you want.
PSP's compression algorthim is why a JPG will increase or decrease in size. When they first introduced it, the default setting would drastically shrink the image and people freaked out. They were afraid they were losing massive amounts of detail. When what was really happening is the algorithm was just really effective. Oddly the reverse is also true, when very little compression is applied the image jumps up in size, or if the algorithm that originally made the JPEG was more effective than PSP's then it'll appear to jump in size.
It's just how JPEGs work.
The best option would be to use Save As instead of "Save" as this will give you a slider (assuming you're using one of the lastest versions of PSP) right in the save dialog with an estimated resulting file size. So you can just move that slider until it matches your desired file size.
agoodphoto
Re: resizing image
thank you, I did not know this information.
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Re: resizing image
Post by hartpaul »
In addition I found in earlier days when I had to get an image of fixed pixel size down below a certain KB setting that rather than change the compression which changes the overall image, I could selectively soften some unimportant parts of the image (soften brush) eg background trees, and this would reduce the disc size (KB) when I saved the image.
agoodphoto
Re: resizing image
thanks for the suggestion, hartpaul.
rondo
processor: Intel I5 6600k 3.5 GHz
ram: 16 GB
Video Card: Nvidia 1060
sound_card: creative x-fi
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Asus ProArt
Corel programs: PSP X6, X9, Aftershot Pro 3, Painter
Re: resizing image
Post by rondo »
Jpeg Optimizer works well, no guesswork.
agoodphoto
Re: resizing image
I have PaintShop Pro 2018. Please tell me where this Optimizer is located, thanks.
ehume
processor: i7 4770k
Re: resizing image
Post by ehume »
On the File menu, find this:
Then do this:
agoodphoto
Re: resizing image
thank you so much.
